M105 issue
  • M105 issue
    So I was detailing my own car with the g220 and M105, got AWESOME results! very very pleased with all the products I used.
    The thread of the detailing: http://www.meguiarsonline.com/forums...int-correction
    One issue I had is with the M105, I guess I did something wrong, maybe chose the wrong pad? I used M105 with the red pad W7207:
    I got lots of dust when cutting through the paint, I mean A LOT of dust, a few things I would like to mention in order to make things more clear:
    1. I use enough product, not too much, not too little. applying the shape of an X on the pad.
    2. I do a section at a time, like 45x45cm I guess.
    3. Used the G220
    4. Cleaned the pad using a brush I have (not a meguiars product, couldn't get this one at the store) like every 2-3 sections.
    5. worked with a wet pad, just sprayed it with some quick detailer every now and then (same with the brush here-couldn't get the final inspection...)
    6. dust was mainly while working... only a bit when removing it later.
    7. outside temp was like 30c but i was working in the shade with ventilation. you wouldn't get better than that
    8. speed set on 4-5
    I assume I did something wrong, maybe th quick detailer can't replace the Final inspection? of maybe too large area? maybe didn't clean it enough while working?
    I would be glad to hear what you guys think, I got great results but cleaning all this mess from the dust was a hard work.
    Note: I read this thread: http://www.meguiarsonline.com/forums...dust-with-M105
    But still my case is a bit different...
    So let me know what you think, I got my dad's Buick le-sabre waiting for me, and I don't want to repeat this error
    Thanks,
    Sahar.
    Re: M105 issue
    You used way to much.
    After the pad is primed you should only use a few drops.
    105 or any compound will dust.
    DetailingByM.com
      Re: M105 issue
      Way too much product? or way too much liquid (QD) ?
      Also, what do you think of using the QD instead of the F.ISPECTION?
      Thanks!
        Re: M105 issue
        Originally posted by CorradoT5 View Post
        One issue I had is with the M105....
        Thanks!
        105
        DetailingByM.com
          Re: M105 issue
          One of the ways I read that works really well with M105 is to use Mineral o
            Re: M105 issue
            OMG. Don't do this.
            Don't add anything to any product.
            Learn how to use it.
            Even water screws it all up. I know, I know people use water all the time.
            I've never added anything to 105 and it's worked on everything I've come across exceptep for a crappy Single Stage that was extremely dry.
            But out of the thousands of cars 105 has worked on 99% of the detailers don't add anything especialypeicaly oil, geesh.
            DetailingByM.com
              Re: M105 issue
              Wow, almost all of my message did not save.
              Thankfully the issue with posting is resolved.
              Ok so here is what I was saying:
              Using Mineral o
              ****... lost 3/4 of my message again. I am done with this site.
