Endurance Trigger Spray, Endurance Gel, and Blackfire Gel Comparison
  • Endurance Trigger Spray, Endurance Gel, and Blackfire Gel Comparison
    Having established what I think is a pretty solid car care routine for my new Hyundai, I'm beginning to experiment a bit with different products, purely out of curiosity. For the past two months, I've been using Endurance Trigger Spray as my tire dressing of choice, and I've been very pleased with its appearance. I have yet to put its longevity to the test, as I typically wash my car every 5-7 days.
    That said, as I'm beginning to detail the occasional car for a friend or family member, I want to be able to offer a couple different product options based on my "client's" preference. While I tend to stay away from gel-type tire dressings these days as a result of difficulty I have had in the past with removing such a dressing, I've learned a lot about cleaning techniques and products thanks to MOL, so I thought I'd give gel dressings another try. AG recently offered Blackfire's Long Lasting Tire Gel as a BOGO deal which I decided to take advantage of - Blackfire claims that their gel contains no petroleum distillates, which makes me think it may be an easier dressing to remove (thereby limiting buildup). Considering how happy I was with the Endurance Spray that I had been using, I ordered a bottle of the Endurance Gel, also.
    My plan is to test out all three products, comparing both their durability and appearance over time. I'm going to continue to wash my car as usual, but I will not be cleaning the tire that I'm using to evaluate the these dressings until all three have lost their shine. My car is driven about 20 miles on a daily basis and kept outdoors 24/7, so the test tire will be exposed to a fair amount of South Florida heat, humidity, and rain. I plan on taking pictures of the tire every day, and updating this thread every few days. I'm guessing that this test will last for 2-3 weeks, but we'll see!
    I started by cleaning the test tire to the best of my ability - it was soaked in Super Degreaser @ 4:1 for about five minutes, scrubbed with a tire brush, rinsed, soaked in APC+ @ 4:1, scrubbed again, rinsed, and soaked a second time in SD, scrubbed, rinsed, and dried. Despite this thorough cleaning, the tire still looks pretty good, even though it feels dry and non-greasy to the touch - definitely a testament to the durability of the Endurance Spray that had been used up until now.
    After cleaning, I divided the tire into thirds, and applied each product using a foam applicator sponge from SM Arnold (I used a different applicator for each product to avoid cross-contamination). I prefer this type of applicator over the curved kind, as the curve never seems to match up to my tire quite right. I'm also a big fan of the built-in case, which makes it easy to store the applicator for future use without having to deal with a greasy plastic bag. I typically get about two months of weekly use out of an applicator before the foam begins to fall apart.
    After waiting for the recommended ten minutes for the first coat to dry a bit, I applied a second coat of all three dressings.
    I then removed the tape dividing the three sections...
    ... and took some close-up shots.
    As you can see, the Blackfire has a noticeably higher gloss than either Endurance product, but then, Endurance isn't really intended to be the glossiest dressing in Meg's consumer line (hence the name). It would probably be more fair to compare the Blackfire gel to Hot Shine, but I didn't have any of that on hand.
    It's also interesting to note that the Endurance Spray seems to be marginally more glossy than the Endurance Gel. I applied both products in the same manner, taking care to work the dressings into the grooves of the tire as much as possible for an even appearance, as well as to lessen the chance of sling. I think that the Spray tends to even itself out better than the Gel, whereas the Gel requires a bit more focus on carefully spreading it around the tire with the applicator.
    I'd also like to note that the flip-top cap on the Blackfire bottle, combined with the fact that the Blackfire gel is fairly runny, makes getting the gel onto the applicator a messy affair. The Endurance Gel bottle cap is slightly better. Frankly, while I love Meg's products, I'm less than impressed with the bottles they choose to sell their consumer line of products in. I much prefer the self-cleaning bottles from the MF system - If I decide to continue using either gel in the future, I'll definitely be putting them in a better dispenser.
    That wraps it up for now. As I said, I'll update this thread every few days with pictures, mileage driven, and weather conditions.
    Re: Endurance Trigger Spray, Endurance Gel, and Blackfire Gel Comparison
    Nice pictures and writeup, while all three look good I have to hand it to Blackfire. I have some Endurance gel, but I think I might have to pick up some hotshine -- I just like the glossier look, and I'm guessing it's cheaper and easier to get than Blackfire. Endurance does last quite a while, and I do like gels.
      I have seen 2 versions of Endurance tire gel before.
      One is standard while another one states "high gloss" on the bottle.
      It seems to me that your bottle of tire gel is the standard version?
      I have compared the Gold Class Endurance High Gloss tire gel to Hot Shine tire foam and NXT insane shine before.
      I would say Endurance High Gloss is the most economical and quite long lasting but aerosol products are less messy, just spray on and walk away. I prefer liquid products to be in a thinner consistency.
      Look wise, if you get the High Gloss version of Endurance it is very shiny, making my tires look they are wet.
      and talking about wet... water beads on tires if you drive in rain.
      Dennis
      Nissan Fuga | 日產 風雅 | 日産 フーガ
        Dennis - The Endurance that I have is the new formula, and says "Long lasting, high gloss shine" on the front of the bottle.
          Day four update: Driven about 38 miles, rained on three times (though not driven in the rain).
          I washed the car this morning, and as planned, I cleaned the wheel, but not the tire, though it did get rinsed.
          Still looking good, though the Blackfire lost its super-wet look after the first day. No sling whatsoever - I let the tire dry overnight before driving.
            I like M40 or HD on tires but they would never last this long.
              Nick - I started out using HD on the wheel wells, as it's great for spraying and walking away. Lately, I've been using ASD, but the splash guards on my car really don't absorb that particular dressing. They look great right after a wash, but as soon as I drive anywhere, they collect road grime like crazy.
              The benefit to using HD on anything, I imagine, is that it's really easy to wash off, so there's no risk of building up residue over time. I'm pretty sold on the Endurance spray at this point for its, well, endurance, but I've still got to find a good way to completely remove it from my tires periodically. APC @ 4:1, SD @ 4:1, full strength Purple Power - nothing I've tried yet seems capable of removing it completely. Yeah, Endurance is pretty resilient stuff.
                If your looking to remove it 100%, try using some Goof Off or Tarminator after washing with a terry cloth towel.
                  Would Body Solvent be a safe substitute, provided the tire is washed with regular soap and water afterwards? This isn't something I would do with every wash, but maybe every six months or so when I do a full detail.
                    Day nine update. It rained heavily here three days in a row, and I had to drive in it, so the tire has lost a lot of gloss, but it still looks good. Total mileage as of today is 117. The car has also been washed for a second time since starting the test, so the the tire has been rinsed quite thoroughly in addition to all of the wet weather.
                      Double post. Oops.
                        Double post. Oops.
                          Alright, third time's the charm...
                          After sixteen days, three washes, plenty of rain, and 250 miles driven, I decided to bring this test to a close.
                          A few thoughts before I post the final pictures:
                          - Endurance Spray is the easiest of the three products to apply, especially if your tire has grooves like mine on the sidewall
                          - A brass-bristled brush is a must for cleaning those grooves. I was amazed by how much crud had built up in mine over the past four months
                          - Blackfire offers a much wetter initial shine, but this disappears after a couple of days, while both Endurance products retain their gloss for up to a week of daily driving
                          - All three products still appeared presentable after a couple of weeks as long as you don't look too closely
                          - No matter how good the dressing, tires on a daily driver are going to be exposed to all kinds of dirt and brake dust that will, over time, affect the appearance of your tires
                          Final pictures:
                          Some side by side shots:
                          Thanks for looking.
                            Thanks for taking the time to perform and document this test.
                            So what's your conclusion? The appearance of all three products look very similar in the photos. Any discernable difference in real life?
                              It all depends on what you're looking for. I like some gloss, but ease of application is more important to me, as is durability as far as rain is concerned. While the Blackfire gave the tire a true "wet" look for a couple of days, I preferred the appearance of Endurance. Blackfire was more of a deep black, while Endurance seemed to reflect a bit of color, which I liked.
                              Overall, I give the edge to Endurance Spray - it's easy to work with, stands up to rain well, and retains a high gloss for at least a week (if it's not driven in wet weather) - that's plenty for me, as my car is washed at least weekly. Even if you wash your car less frequently, the dressing fades to a nice matte black, and doesn't visibly accumulate brake dust (the real cause of "browning," I think) for about two weeks. I don't think you can expect much more out of any tire dressing on the market when used on a daily driver.
