I needed some new polishes, since the ones I have been using just didn't have enough cut for some jobs. So after reading on a few different found, I decided to order some Ultimate Compound and Ultimate Polish, since a lot of people seem to say that they cut really well and do not create a lot of hazing like typical compounds. I am prety new to the SMAT technology that is in some of the Meguiars products, before all I have used is diminishing abrasive polishes. So I am used to lightly misting a pad with pad prime or water before actually applying polish to the pad.
Now I have been reading different articles and techniques regarding M105 pad priming, but it seems everyone seems to have their own technique and it makes it kind of confusing to understand. Some say spread the polish over the pad surface just enough to cover the pad, while others say use a couple pea sized drops. Does this same sort of pad priming technique apply with the Ultimate Compound and Ultimate Polish? Do I not need to mist the pad before applying the product?
Also, with the Ulimate Compound and Ultimate Polish, how can I tell when the polishes are ready for removal?
I have a couple newer GM vehicles that I am going to be working on this weeked, both darker colors. I will be using both the UC and UP with my PC 7424 (non xp version). I know that GMs usually have a pretty hard finish to them, so do you all have any tips you could share with me when it comes to using these products on these types of vehicles, such speeds and pressure I should be using the with the UC and UP on the 7424 to get the best results?
I was thinking of using 5.5" LC pads for the UC and 5.5" white pads for the UP. Does this sound like a good combo for most GMs, or should I get some LC black pads for the UP?
