You don't have to wash them right away. I usually wait until I have twenty or so then throw them in the wash. The only ones I don't wash are the ones I use for tire dressing.
Originally posted by Lt1Corvette You don't have to wash them right away. I usually wait until I have twenty or so then throw them in the wash. The only ones I don't wash are the ones I use for tire dressing.
I do the same... I have tons but I like to re use them not to crazy about tossing them after one use. As they get worn I demote them to less important jobs, applying dressing to wheel wells or any other dirty job.
I tried washing them in the machine - but it tends to float and not all of the chemicals come out. i tend to ring it out w/ a towel by squeezing it out when I can...
To avoid confusion, I think we need to distinguish between applicator pads and buffing pads.
While most of us wash the applicators, the washing of the buffing pads is not recommended.
For the applicator pads, I take a towel and wrap it around the pad. I then squeeze the pad as hard as I can to work out any excess product. Then, I will place them in the washing machine with hot water and a mixture of liquid Tide and Dawn soap. This usually does the job quite nicely.
I'd be wary of zip-loc'ing either app pads or buffing pads when they are damp with product. I've only done this with buffing pads, and had one mildew on me (which has been reported here previously). Actually I was following the Meguiar's advice about putting it in a bag and not sealing it, but I put it in a container with some other pads, and it got buried and couldn't breathe.
Probably the best way to wash your hand applicator pads for re-use is to use a combination of cleaning/washing by hand, and then washing in a washing machine on the hottest setting with a quality laundry detergent.
Ringing a wax pad inside a terry cloth towel and extracting most of the built-up product is a great start or stand alone method before washing.
Follow this with washing and ringing by hand under warm/hot running water with dish soap is a great follow-up to the towel ringing. At this point you can either allow them to air dry, or you can continue by washing them by machine and then either drying in the dryer or allowing them to air dry.
Originally posted by Setec Astronomy I'd be wary of zip-loc'ing either app pads or buffing pads when they are damp with product. I've only done this with buffing pads, and had one mildew on me (which has been reported here previously). Actually I was following the Meguiar's advice about putting it in a bag and not sealing it, but I put it in a container with some other pads, and it got buried and couldn't breathe.
A friend of mine had this problem as well. No to zip-lock, leave the top of the bag open.
