Claying glass
  • Claying glass
    Is it OK to use the clay used for the paint, for the glass? Or should I use a new, clean clay?
    I wonder about this for some time. I know that auto glass is not as sensitive as paint (especially the clear coat).
    Re: Claying glass
    Yes, it wiil be ok.
    I just do the glass while doing the paint as well, not nessicerily using 'used clay'.
    Wheels, mufflers, etc would get seperate, older clay.
      Re: Claying glass
      Yes you could use the same piece of clay. You will be amazed at the difference after claying your glass.
        Re: Claying glass
        I tried it once on my windshield, and what a difference it made. It was a lot easier to wipe and clean.
          Re: Claying glass
          For the windows do you guys also use the same lubricant as you used for the rest of the car?
          Richard
            Re: Claying glass
            Yes, same QD
              Re: Claying glass
              After claying, you will want to use a glass cleaner to remove residue.
                Re: Claying glass
                Yes, I use the same lube for claying glass. Then clean the glass with your window cleaner of choice.
