UQD Drips
  • UQD Drips
    I've gone thru several bottles and it seems like every other bottle has a problem with the spray pump, the problem is leaking and an uneven spray pattern, anybody else ? i'll keep the good spray pumps out of an empty bottle to replace the bad one but it seems like this is an ongoing thing
    Re: UQD Drips
    I think there is a plastic saftey you need to remove before using it, otherwise you can run into that problem.
      Re: UQD Drips
      Check out this thread: http://meguiarsonline.com/forums/showthread.php?t=35492
        Re: UQD Drips
        Thanks Ciera, guess i'm not the only one, didn't catch that post
          Re: UQD Drips
          mine works great!
          I noticed that of all my products, UQD lasts a lot longer due to the fine mist spray
            Re: UQD Drips
            I have the same problems, I think the bottles are junk. but I switched the Ulimate detailer into the quick spray bottle and ran into the same problems what I noticed while pouring the UQD into the other bottle there were smalle white clumps maybe that causes the problem I have no idea.
              Re: UQD Drips
              bought UQD bout a month ago to try it out
              halfway through my car, the sprayer breaks
              so now to spray it i have to take off the black top and press down on it..
                Re: UQD Drips
                I hope Meguiar's picks up on our (cough) subtle hints and improves the UQD and UQW sprayers. I've been having problems with my other UQW sprayer lately. It sprays once, drips while you try to get it to spray 4 or 5 times, then it sprays again. I put a different sprayer on my UQD bottle and haven't had any problems with that sprayer.
                  Re: UQD Drips
                  I use M135 in a detailer line spray bottle, and love it! I didn't realize how bad the UQD style bottles are until I used the above, lol. Get a regular spray bottle and sprayer. Worth every penny of making the switch IMO.
                    Re: UQD Drips
                    I havn't came across any problems with mine,so far. I also like the fine mist it produces. Inside,the mechanism seems pretty standard.
