I have M80/M83 and I have M105/M205 on order along with some other goodies . Assuming I have these fine products already, does UC or SwirlX give me any additional capabilities to do my best work?
Ultimate Compound & SwirlX - Where do they fit?
Re: Ultimate Compound & SwirlX - Where do they fit?
if using the method of the least aggressive product first, if you use 80 with no luck, then swirlx no luck, then 83 no luck, then UC no luck, THEN 105... do you get my drift?? I think they say that swirl x might have about the same cut as 83, but I think i'm right in my suggestion though.Fergy-
They can. Often times I can't get my G100 in every nook and corner but the finish of the paint is the same and doing the area by hand with the same product one would use by machine would not turn out as good. Hence, SX/UC by hand and some passion makes up for that!
Get a bottle of each as part of your weapons against Swirls.....Philippians 2:14 - Do all things without grumbling or questioning,
Originally posted by BigLouie View Postdoes UC or SwirlX give me any additional capabilities to do my best work?
The new SMAT products truly finish out better in most cases on most paints, there's no for sure thing and you won't know which product finishes out best on any particular paint system until you test the products out and compare the results.
If it were a job for a customer, I would opt to use the new SMAT products first and then fall back on DAT products in the SMAT products were not working.
Just the wipe-off factor for the SMAT products is a big bonus in most cases.
What's the difference between Meguiar's Super Micro Abrasive technology and Meguiar's Diminishing Abrasive technology?
