DA with Gold Class?
  • DA with Gold Class?
    I have a bottle of Gold class, that i do not use often, because I have the GC paste. When my tax return comes in, I plan to get the DA polisher. How do i know if my bottle is 'DA safe' ?
    My automotive related blog! http://hereishowiviewthings.blogspot.com/
    Re: DA with Gold Class?
    Waxes and sealants are generally da safe. What I mean by this is that you are using the pad on the da to just apply the wax/sealant as these will not correct the paint in any way.You are using the machine at about speed 2-3 for the aplication of the wax/sealant to make sure you are applying a thin even coat of you chosen wax/sealant. When useing the da for applying the wax/sealant make sure you use a 9006/9207 finishing pad. Hope this helps you out.
    Andrew
    2013 Race Red F-150 SCREW
      Thanks man! I will eventually need lessons on what pad goes with what.
        Its really not to hard to figure out. When using the DA polisher you can use 8006/8207polishing pads, 9006/9207 finishing pads, DO NOT USE the 7006/7207 cutting pads. All of the cleaner polishes,80,82,83,205 can be used with the polishing pads, DA approved 105 gets the polishing pads. For the finishing pads you could use 80,81,82,205,and your LSP.
        Andrew
          What do I need to use the cutting pad with?
            Well with the DA Polisher the cutting pad is not recommended to be used at all due to the marring that it could instill into the paint. You can use them with a rotary if you have one and are good with it. You could use the cutting pad with the rotary and 84,85,and 105. If you get a pc get one 7006 cutting pad and about 6 micro fiber bonnets. You rap the bonnet around the cutting pad and use it to remove your wax/sealant afterit has cured. Once again hope I helped you out.
            Andrew
