Can I use DA to apply DC1 ? Which pad should I use, a polishing or a finishing pad ?
DC1 Application
Re: DC1 Application
Yes, you can use Deep Crystal System Paint Cleaner (Step 1) with a Dual-Action Polisher. I would recommend using the yellow Soft Buff Foam Polishing Pad (if you are working with the 5" backing plate you would use either the W-8006 or W-8207). I would apply with a yellow foam pad to a small area (one square foot), and then remove with a micro fiber towel.Rick McDonough
1.800.854.8073 * 3853
rmcdonough@meguiars.com
Re: DC1 Application
Originally posted by Rick McDonough View PostYes, you can use Deep Crystal System Paint Cleaner (Step 1) with a Dual-Action Polisher. I would recommend using the yellow Soft Buff Foam Polishing Pad (if you are working with the 5" backing plate you would use either the W-8006 or W-8207). I would apply with a yellow foam pad to a small area (one square foot), and then remove with a micro fiber towel.
