Ok, tomorrow is supposed to get up to 55, so I'm going to wash my car and the use #9 and then NXT. Now my question is #9 a paint cleaner b/c it removes oxidation and swirl marks and will this work well with NXT. What is the best way to apply #9 by hand, should i pretend like i'm rubbing out a stain or do i just apply moderate pressure. Now in a back and forth or circular motion. Also, with NXT do i apply this with light pressure or do I rub this stuff into the paint also? And back and forth or circular? It's spring cleaning time and I want to do it right. Is it better to apply the NXT and let is sit for a few hours or overnight before I buff it off? I keep hearing people talking about curing time? How does this effect NXT. Thanks in advance.
#9 2.0 and NXT
sonicblue02.... I used #9 2.0 for the first time yesterday on my truck and ss 2hotford said on the #9 the key is to rub it in untill just before it drys then wipe it off, make sure you only do a small area. It took me two or three tries to get it right but once I started to use it, it worked well and applied easy and removed easy.
On the NXT 2hotford said it well, you will find NXT VERY easy to use!Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
