Best pad to use in NXT 2.0 Removal?
  • Best pad to use in NXT 2.0 Removal?
    I have a finishing pad and a wool pad for my 7" Orbital. Which would give me a better result in removing NXT2.0?
    Ed
    Re: Best pad to use in NXT 2.0 Removal?
    Hi Ed,
    Few things I feel should be mentioned here: for starters, I do not think a 7 inch orbital works well with wool under any circumstance. Wool is used on high-speed rotary buffers in order to work properly.
    Secondly, for removing NXT after it has dried (Use the swipe test with your finger to test if it is smearing or not. No smear= ready to remove) you can either use a microfiber bonnet OVER a pad, or most just use a microfiber towel by hand. You shouldn't be using a pad itself to remove the wax.
    Hope this helps.
    Mark
      Hi Ed,
      Hope this helps.
      Mark
      My bust, it is a high speed rotary. I just put in orbital on autopilot.
      Hmm, Microfiber over the foam finishing pad sounds good.
      Getting ready for a Mercedes show tomorrow.
      Thanks mucho.
      Ed
        No problem Ed!
        Makes sense.
        Just to be clear, a finishing pad is what you want to use to APPLY the wax (non-mechanical pad, ie no abrasiveness), and then you can use either a polishing or cutting pad WRAPPED in a microfiber bonnet to remove the wax (Some like the hard pad under the bonnet, some prefer softer for curves etc).
        Have fun tomorrow!
