Originally posted by rwlc5 After applying the NXT wax, does it need to be topped off with any type of product? If so, what? What detailing spray would you recommend?
Hi rwlc5,
Welcome to Meguiar's Online!
NXT does not need to be topped with anything. Best results with any wax is usually achieved with 2 well applied coats versus a single application.
Some people like to play around with their waxes and try to go for and even deeper, darker looking result. To date, I haven't seen the need for it. However, if you want to try topping, then I suggest reading this first.
As far as spraying on the NXT Spray Wax, this is not necessary. The NXT Spray Wax is merely an in-between product for use in-between normal car washes and regular coatings of the NXT Tech Wax.
It is not a necessary component of the NXT system, just a complimentary product.
