Prep question
  • Prep question
    Can I (should I) use #1 Paint Cleaner & # 2 Polish of the Deep Crystal System with the NXT wax? How should the NXT final results compare to using the #3 Deep Crystal Carnuba Wax?
    2003 Mach 1
    Azure Blue
    5 speed/IUP
    2007 Tacoma DC 4x4 TRD Off-Road
    KY Horsepower
    I see no problem in using the #1 & #2 steps from the Deep Crystal system for preping a finish before using NXT, they are completely compatible. I've never used the #3 Carnuba Wax so I'm going out on a limb here...my guess is that the NXT will protect longer than the #3CW since it is a polymer which last longer than carnuba based waxes. As far as finish the NXT will leave a deep, very glossy and very reflective look while I'm guessing the #3CW will have that warm glow and soft reflections that most carnuba based waxes have.
    2000 Pontiac Trans Am WS6
    Bright Silver Metallic / Ebony Interior
    ASC# 1,575
    406 rwhp 392 rwtrq
      i just used the nxt wax today for the first time and all i can say was wow i have used the 3 step system in the past with good results .today i washed with the nxt wash and then i clayed with the meguirs quick clay and then used scratch x and then the tech wax it looked pretty good and then when the sun came out oohhh snap the paint looked so wet and clear ith of metalic i would recommend this to anyone aswell as the other products mentioned above so i think you will be happier with the tech wax
        I have used all three steps in the deep crystal system and they work great. I could only get the #3 to last 3 weeks 4 at the most. I have also used #1 and #2 then NXT it worked great as well, the nxt has been on my truck for 6 weeks now and its still there. So..... I would go with the 1, 2 and NXT I also think the NXT looks better.
        Brandon
        2007 Black Chevy Avalanche
        My Albums: Avalanche
          Great, thanks for the insights! I look forward to using the NXT wax!
          2003 Mach 1
          Azure Blue
          5 speed/IUP
          KY Horsepower
            One more thing MattN03.... If you have the time I would recommend a second coat of NXT 24 hours or so after the first coat. I had a noticeable difference after I applied the second coat on my truck. I am a believer in the second coat I am sure you will find others that are as well.
            If you can, post some pictures when you are done maybe even before and after.
            Brandon
              I would be happy to post pics, but I don't have a digital camera The car isn't a daily driver, so it's always spotless & stays under a car cover. I'll be getting it ready for the 40th Mustang Anniversary show in Nashville, TN in April, so I'll DEFINATELY find time to put two coats on I'm hoping to bring home a trophy in the car show
              2003 Mach 1
              Azure Blue
              5 speed/IUP
              KY Horsepower
                One more question: I read that many are not hand applying the wax. Will it be a problem if I apply it with a rag instead of a buffer?
                2003 Mach 1
                Azure Blue
                5 speed/IUP
                KY Horsepower
                  Good luck!
                  If you get a chance between now and the event in April, I would highly recommend applying the NXT Tech Wax using the porter cable dual-action polisher. Yesterday, here at Meguiar's, we applied the NXT Tech Wax to over a dozen trucks using the PC.
                  While using your hands will result in great results, there is something to the polishing action generated by the porter cable dual action polisher that's pretty hard to beat for a show car shine.
                  On a couple of trucks, all we did was apply the NXT Tech Wax and remove. We would then pull the truck out into the sun and inspect. In all cases, the finish was more clear, more reflective with high shine and excellent gloss. But, there were still some signs of the cobweb-effect.
                  With other trucks, we would first apply a cleaner/polish, (#83 DACP), using the PC followed by the NXT Tech Wax and afterwards, pull the truck out into the sun to reveal a swirl free, flawless finish.
                  If you’re serious about winning a first place in April, and at any future events, the small cost of a porter cable dual action polisher plus a few buffing pads is well worth the investment. One more product I would highly recommend and that’s the new microfiber polishing bonnets Meguiar’s offers for the small 6.5” foam polishing pads. I don’t know why, but they really seem to bring out a high gloss finish when used to remove the NXT Tech Wax.
                    How much would the PC polisher cost & is it goof proof? The last thing I want is to accidently harm my paint because I've never used a polisher before
                    2003 Mach 1
                    Azure Blue
                    5 speed/IUP
                    KY Horsepower
                      Do not apply with a rag. Use the soft foam applicator pad that comes with the wax. If you drop it, or lose it, take the time to obtain some more for the application of your wax. It sounds like you have a very nice car, worthy of display at a car show.
                      Do not use a rag of questionable quality to apply any wax. You end-up with cloth inflicted scratches. Meguiar's sells extra foam wax applicator pads at a very reasonable price. Stock up on them so that you always have clean wax applicator pads ready to use. Also invest in plenty of microfiber polishing cloths. These will insure a clear, streak free, high gloss finish without worrying about cloth inflicted scratches when removing you wax.
                      If you do a good job of thoroughly applying one to two coats of the NXT Tech Wax you should get awesome results.
                      Hope this helps...
                        The porter cable dual action polisher can be purchased at numerous online locations and other retail stores for under $150.00 This doesn't include a backing plate or a foam polishing pad and only comes with a one year warrenty.
                        Meguiar's sells this polisher with a life time warrenty for $225.95 This includes a backing plate and one foam pad.
                        Follow this thread as I continue to post pictures. Most of the people at this event have never used the PC before.
                        http://www.meguiarsonline.com/forums...=&threadid=164
                          Ok, that just opened up a few more questions...
                          I have 3 or 4 of the Meguiars foam applicators & the new one that came with the NXT wax. Can I wash these after each use & reuse them or should I dispose of them? Also, I bought the 100% cotton terry cloth towels in the Meguiars catalog to take the wax off. Is this a good idea or should I be using the microfiber polishing cloths? Thanks for the help!!
                          2003 Mach 1
                          Azure Blue
                          5 speed/IUP
                          KY Horsepower
                            If you shop around you can find a Porter Cable 7424 for $119.00 maybe even $109.00 try www.amazon.com I think they have free shipping. Then call up meguiars and get the Kit containing the hook and loop backing plate, 2 polishing pads and 1 finishing pad I think it cost me $35.00 from meguiars. If you were to go with the Meguiars one.... as Mike pointed out they will give you a lifetime warranty...
                            I like Microfibers for removing wax but I am sure the Meguiars 100% cotton towels are very high quality and will work fine without scratching.
                            Brandon
                              Your new Porter-Cable
                              Here's where you can find it cheap!
                              Porter-Cable 7424 Kit
                              Many of us from Autopia have ordered from this company, and they offer the "PC" at this price mostly due to the replies from Autopia members. It comes with the 6" counterweight as well.
                              You will get it very quickly too! Got my Makita 9227C from them.
                              Regards,
                              Deanski
