NXT 2.0 and glaze?
  • NXT 2.0 and glaze?
    I read up on layering NXT 2.0. I only top it with another thin layer of NXT 2.0. I was wondering if after I polish could I apply a glaze then the NXT 2.0? Or will the NXT remove the glaze?
    Re: NXT 2.0 and glaze?
    are you referring to something like # 7 Show Car Glaze? If so that is a pure polish and you would want to apply something like NXT 2.0 after polishing
    Jon's Premium Auto Detailing
    210-281-8151
      after polish (removing all the defect in regard with any polisher) you need a layer of sealant (e.g M21) or wax (e.g NXT, M16, M26) to protect the clear coat
        The act itself of rubbing the surface will in fact remove any residue or layer of oil on the paint.
        Like if you use #7 Show Car Glaze you can top it with NXT 2.0 and the action of rubbing (applying) NXT on your surface will remove some of the oils on the surface of the paint but it's something insignificant.
        So you can do it, and this doesn't mean that when you are applying th wax you are removing all the oils #7 has put
        Do you understand?
          I was goin to polish the car then apply a wet glaze from Danase then the NXT on top of that.
