Will the polymers "set up" or crosslink properly if the car is covered immediately after waxing with NXT, or is it best to leave it uncovered during this process?
The answer to your question is uncovered. As in, apply the wax, allow to dry to a haze, this is usually 10-15 minutes, then remove the wax and then your done. You don't need to cover the car. I'm pretty sure what you want is time to pass and the polymers that have been left behind to be exposed to air.
