UQD vs QD?
  • UQD vs QD?
    Whats the difference between quik detailer and UQD?
    Re: UQD vs QD?
    The only thing I can say is the original Quik Detailer is a great detailer. Ultimate Quik Detail has hydrophobic technology and gives incrediblebeading action. I've gone from Quik Detailer to Ultimate. I'll use up the Quik Detailer I have as a clay lube but it's UQD for me from now on !
    Bill Poirier
    West Seneca, NY 14224
      Re: UQD vs QD?
      I agree, but it should be noted that UQD is NOT recommended for use as a clay lube.
        Re: UQD vs QD?
        I just got some QD in the clay bar kit and was wondering what was up. I'd rather use a soap solution to save it if it was as good as the UQD. Due to lack of availability of meguiars products I purchased a Mother's kit... I loved that QD! I'm sure Meg's is better, and if the UQD is best I'll just burn my QD on the claying.
          Re: UQD vs QD?
          The clay kit comes with QD because you shouldn't use UQD or soap/water mix to clay with.
            Re: UQD vs QD?
              Re: UQD vs QD?
              Agreed, water and clay are not the best mix...I've also gotten a gallon of Final Touch and dilute it 2:1 for my clay lube...cheaper and very effective...fwiw..
              Bill Poirier
                Re: UQD vs QD?
                I don't think we can have a QD vs. UQD thread without mentioning the improved ease of removal and non-streaking abilities. The UQD is very hard to make streak and will usually be removed in a swipe or two while sometimes QD might streak and need three to four swipes with a microfiber to remove.
                I notice in the winter that most products are a little tougher to remover without streaks but UQD is very easy to remove even in colder climates.
                "Difficult takes a day, impossible takes a week." Jay-Z
                  Re: UQD vs QD?
                  Copied from Meguiars.com
                  Quik Detailer
                  Meguiar's Quik Detailer keeps a waxed car looking "just waxed". Clear coat safe, Meguiar's Quik Detailer removes harmful contaminants before they damage your finish. Use Quik Detailer right after your car is sprayed by a water sprinkler, hit by a bird dropping, or exposed to any other condition that ruins your "just waxed" appearance. The safe, high lubricity formula lifts off dirt and grim without scratching while enhancing gloss without build up. Details a full sized car in less than 15 minutes!
                  Ps : I used it for claying too
                  Ultimate Quik Detailer
                  The most advanced high bead and deep gloss spray detailer! Meguiar’s®, the company that brought car enthusiasts the world’s first spray detailer, now introduces a revolutionary mist and wipe product that works like a spray detailer and enhances wax protection.
                  Through the use of new Hydrophobic Polymer Technology™, Meguiar’s has created a spray detailer that actually repels water, withstands multiple car washes, and adds additional protection to your finish.
                  Ps : I used it as my wax to up
                    Re: UQD vs QD?
                    Will it hurt any thing if I wax my truck then later that day come back in with Qd to take off all the dust then put the last coat of Gc on?
                    Try to ask this the best way I can
                    Get In Sit Down ShutUp
                      Re: UQD vs QD?
                      That would be best, with the regular QD.
                      I am not sure if UQD would be as good for that, since it leaves its own coating behind, then trying to wax over it.
                        Re: UQD vs QD?
                        From what everyone has said: if your car gets a little dirty or hit by the sprinklers then you would want to use QD first, then UQD to finish off? Seems redundant to me...doesn't UQD help lubricate to remove dirt too?
                          Re: UQD vs QD?
                          Yes UQD does lubricate to help remove light dust or a little bit of dirt without scratching, so you would be fine using UQD only. Sometimes people will wash the car and then use UQD to add a little protection and gloss, but if you are just using UQD to remove a little dirt, there is no reason to use QD first.
                          Lydia's Mobile Detailing
                          2007 Honda ST1300 - Silver
                            Re: UQD vs QD?
                            So I can GcWax on at 9 Am later that day use UQD to take off the dust then put the last coat of Gc wax on?
                              Re: UQD vs QD?
                              My only concern is that because UQD leaves its own coating behind, it may affect how the wax goes on, or applies, etc.
                              It probably is not enough of a coating to worry about, but might need Mike or Mike or Tim to chime in on this one.
