body scrub with pc
  • body scrub with pc
    hey everyone,
    this is my first post on meguiar's online and i was wondering if Body scrub is safe to use with a PC. I will betting the PC in the very near future.
    2013 Race Red F-150 SCREW
    Re: body scrub with pc
    Originally posted by onawrxhigh
    hey everyone,
    Welcome!
    I don't see you having problems. I think that the Consumer Line is more geared towards hand application rather then Machine.
      Hi onawrxhigh,
      Welcome to Meguiar's Online!
      The directions on the back of the label for Clear Coat Body Scrub state that this product can be used with an orbital buffer.
      Orbital buffer oscillate at fairly slow speeds and often times have much larger surface areas compared to the pads that are used on the PC. Conversely, the PC has the option to run at very high speeds by adjusting the variable speed setting.
      I would be cautious about using the Clear Coat Body Scrub with a PC at high speeds. Always test any product you are unfamiliar with in a small area before applying to the entire finish.
      Clear Coat Body Scrub Paint Cleaner
        hey mike,
        I used the body scrub about two weeks ago with the pc. I used a setting of two on the pc and worked the product into the paint. I used this product by hand before on other cars so i know when it has been worked enough. I had only one problem and that was with removal. The towels were almost sticking and loading up really bad. I read a post that was geared to the deap crystal paint clearer that stated when it was used with a pc to do one panel at a time. I will try this next time. I feel this has helped tranform my paint because my aspen white wrx has never looked better.
        Andrew
