M62 use in foam cannon
  • M62 use in foam cannon
    Hey everyone hope you're all safe and healthy first and foremost. Any how my question is can I use M62 in my foam cannon with my pressure washer with proper mixing or should I send just that back and get shampoo plus?
    2001 Audi A6 Avant (wagon)
    Ming Blue Pearl Effect metallic
    2019 Nissan Sentra SV Special Edition
    Super Black
    Re: M62 use in foam cannon
    I have not tried that specific wash in a foam cannon but given the design of the product it should work great.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
      You certainly can... it might not be quite as thick/clingy as a soap for cannons, but will be ok. Just check whatever you diution ratios are (you probably want to dilute a bit in the soap holder) and try for around 128:1.
        Cool I'll post an update a soon as I can
        Super Black
          My soap holder is 32oz. i know for the bucket 128:1 is the proper ratio ex. 5:1 for 5 gallon bucket but for the container what do you mean 128:1? I found a dilution chart from the chemical guys that has all the mixing measurements for all the typical containers used (16oz, 32oz, 1 gal, 5 gal)
          Super Black
            I mean that if you dilute in the soap holder, you need to combine that with the ratio your sprayer dilutes, depending on what is adjustable on yours.
            So if you did 1:4 in the holder, you would set the sprayer at 1:32, get 1:128 total.
