question about MF pads
  • question about MF pads
    i just starting using the MF Da system
    started with the pink compound cutting product and i noticed that after my first 2 by 2 pass all the fibers are flat on the cutting pad
    do i need to use a brush on it after every 2 by 2 pass?
    or is it ok to reapply to a flat fibered pad and move on??
    thanks
    1985 500SEL Euro Nautic Blue
    1998 S500 Brilliant Silver
    2001 S500 Almadine Black
    2005 C320wz Granite Grey
    Re: question about MF pads
    You want to fluff the fibers back. So a brush or compressed air would be good. Compressed air is what I recommend. You want to fluff the fibers before working a new area.
      thats the nice thing about foam, i guess u dont have to do that
      i dont have a air compressor, so i guess i ll just have to use the brush
      how easy is this stuff supposed to be to wipe off,
      i wipe off nxt 2 and mothers syn wax real easy
      this seems a bit tuffer
        You still have to clean foam pads. Working clean gives better results. The brush works fine on MF.
        If the compound is hard to remove you are over working it. I see you are in florida so take the surrounding environment (temp, humidity) as a factor.
          i need to update my location,
          im back in california, orange.
          i probably need some better MF clothes too, something with a thick pyle, might try those uber clothes on DD.
            These work really well. Still can't beat the price.
            The only thing I can think of is that D300 is being overworked and that is making it difficult to remove. Try less passes.
              Constant cleaning goes a long way! It also sounds like you are using too much, only a few light drops in the corners will work fine.
                Compounds and polishes should not dry on the paint. Less passes or smaller areas are recommended. A spray bottle of water can help if worked too long or conditions create an issue ( a light mist )
                BMW ZSCCA Area Rep SoCal
                  thanks, ill do smaller areas for shorter periods....
                    Do yourself a huge favor and read through this article on proper use of the DAMF System. While the basic process is the same as for foam, there are certain tweaks to that process that must be followed in order to maximize results. The DAMF System is a fantastic addition to your DA arsenal, but it must be used properly in order to realize its potential. In all honesty, the only people we hear about who don't like the system are the people who are using it wrong. Once they realize their errors and start using it correctly, their attitude changes rather quickly.
                      Don't forget to prime ur mf pads!
                        thanks for the replys, i read the articles, and watch the autogeeks video with mike stoops on the product and followed instructions
                        i still have a few times when it seems like the product almost holograms it self on to the paint and it becomes so hard to remove where i really have to press hard with the mf cloth. It gives debris like its a pencil eraser
                        in terms of scratch removal....not so much, maybe the scratches i have are too deep,
                        i have half a bottle of fg400 menzerna someone gave me, i might try that
                        tomorrow ill work on the sides of the car and try to keep honing my techiniques..probably sunday will start the wax phase
                          I'm a professional detailer and I love the microfiber system. I have seen that microfiber will give u a better cut then a foam pad but it's worth it. Its a little more work. But If the correction compound is coming off pretty tough u can just put a little of it on. Also u can go over with it with da finishing wax n it will come off easy. Then take a brand New microfiber towel n wipe off follow it will another new microfiber towel with last touch or quick detail to make sure all wax n compound is off
                            It sounds like you could be using too much product. When working with foam pads it is typical that a bead of product in either an "X" pattern on the pad or a ring of product toward the edge of the pad is used. If you continue to do that with the microfiber pads you'll be using far, far too much product. Once the pad is primed properly all you need for working a section is three little pea sized drops of product. Any more will not give you more cut or a better finish, but could make the whole process more difficult. Back way down on the product you're using, work the product until it's just a thin film on the surface, and it should wipe off with extreme ease.
