M101&100
  • M101&100
    Is M101/100 can be used MF cutting / finishing pads with DA. or is designed to be used with foam pads.?
    Re: M101&100
    Many have used M100 and M101 with MF pads with great success. Especially good for heavy defect removal.
    M100 was originally designed to be used with a rotary and wool pad, while M101 was designed for a rotary with a foam pad.
      Re: M101&100
      I have used M101 with MF cutting pads. It does dust more than with foam. At least that was my experience.
        Re: M101&100
        While both were designed with very specific target markets in mind, both also work extremely well when used on microfiber pads with a DA. As The Guz points out, M101 will dust more with microfiber pads than it does with foam pads on a rotary, but it cuts very quickly and leaves a great finish. M100 will dust less, will be just marginally slower to cut (but still extremely fast - remember, speed is relative!!!) while leaving a very nice finish, too, especially on harder paints.
          Re: M101&100
          M101 works great with a MF cutting pad and when used with the Rupes 21- it's a deadly combination. It does dust a ton though. I usually have to re wash a car after going this route because of all the dust, so I only use it when 105 doesn't cut it.
          Dynamic Detailing
          541.668.0480
            Re: M101&100
            That is great information. I would like to ask this:
            I read in another thread that Rupes 21 & M100 with MF finishing pad will leave darn finish even on soft paint which it will be ready to wax, sealant or coating. The question I have how that comb works with Meg DA which the throw is 8mm any one of you guys did try it.
              Re: M101&100
              It's hard to say without actually trying it on a test spot first. All paints respond differently...
