Can You Spray D156 for Final Wipe of RFEW D114?
  • Can You Spray D156 for Final Wipe of RFEW D114?
    I typically wash my car with multiple soaked MF towels from a bucket of diluted RFEW. After the initial wipe or two to remove dirt, and depending on environmental factors, I have one maybe two or three wipes to get the car dry.
    Can I spray on D156 while the panel is still wet or damp (from RFEW) and wipe to a dry surface? Or should I dry the RFEW, then spray on and wipe off the D156?
    Thanks.
    2018 Acura RLX Tech - Majestic Black Pearl
    I use D156 as a dying aid all the time. Works great. You'll get a better layer of protection applying to dried paint. It smells so good use it both ways.
      Re: Can You Spray D156 for Final Wipe of RFEW D114?
      All I can say is as a dying aid, it doesn't seem to be working so great!
      Thanks for the response!
        Theres a bit of a trick I use. That is to prime my waffle weave drying towel with d156 first then spray the panel and wipe. Priming kinda "activates" the drying towel and works much easier.
          I sheet the water off 1st then spray D156 doing one section at a time for final dry.
            Just made a thread here with photos:
            With all the questions on if D156 can be used while drying and or a drying aid I figured that I would document it with photos. After 2 days and 3" of rain here in Raleigh all I did was spray off the truck and sheet off the water and using D156 to dry. Truck yesterday in the rain.. Truck this morning after
