M101-which pads
  • M101-which pads
    Hi,
    For M101 which pads you recommend; it could be used with MF cutting pads and MF finishing pad for cutting and finsihing with DA. If rotary will be used what is the suggested pads to remove swirls and finish the paint to high gloss.
    Thanks to all
    Re: M101-which pads
    M101 Foam-Cut Compound has its own foam cutting pad designed to go with it, but I think it's only available in Europe.
    If you plan to go with a rotary buffer use 6.5" foam cutting pad (W7006):
    you want to limit a pad size and also work on a small area of paint.
    Follow up with M205 Ultra Finishing Polish and either W8207 foam polishing pad or W9207 foam finishing pad.
      Re: M101-which pads
      I use mostly LC orange CCS pad with M101.
      Jim
