paint restoration cream
  • paint restoration cream
    Where does this product fall in. Smat, Damp, Polish. What is it's cutting ability and does it contain polish? Any help would be greatly appreciated.
    BMW ZSCCA Area Rep SoCal
    Re: paint restoration cream
    From AG
    Meguiars Paint Reconditioning Cream D151 uses Meguiar’s cutting edge Unigrit abrasive and polymers to create a one-liquid solution that removes defects, produces incredible high shine with long lasting paint protection. One product does it all! Meguiars Paint Reconditioning Cream D151 is designed to provide fast and fantastic results in a high volume reconditioning facility, detail shop, or dealership.
    Meguiars Paint Reconditioning Cream D151 is aggressive enough to remove severe defects, yet gentle enough to produce a durable swirl free finish. Change Meguiars Paint Reconditioning Cream D151's performance by simply adjusting your method of application. Change from a cutting pad to a light cutting pad, for example, to remove imperfections without holograms. Use the Meguiars G110 Dual Action Polisher for light defect removal and a rotary buffer for heavier paint correction. Meguiars Paint Reconditioning Cream D151 is the fully adjustable polish!
    You can even apply Meguiars Paint Reconditioning Cream D151 by hand for ultra gentle swirl removal with absolutely no holograms.
    “Unigrit" is a feature that describes the size and distribution of the particles on Meguiar’s Unigrit Finishing Paper. The benefits of "Unigrit" are the uniform marks left behind by the paper. With that said, "Unigrit" refers to the mechanical particles in Meguiars D151, which is a very unique type of aluminum oxide. It is very uniform in shape, size and hardness. This makes the abrasives "Unigrit", allowing a very "level" cutting action. Unigrit abrasives allow Meguiars Paint Reconditioning Cream D151 to work longer, level the paint evenly, and deliver a high gloss.
    Meguiars Paint Reconditioning Cream D151 is a one-step solution for busy detailers but the shine gives nothing away. The paint will look as smooth and glossy as if you’d used a multi-step polishing process. For fast defect removal, incredible shine, and wax protection, use Meguiars Paint Reconditioning Cream D151.
    http://www.autogeek.net/meguiars-pai...ream-d151.html
    "STRIFE" aka Phil
      Hey Bob!
      What's going on?
      This thread should help answer some of your questions:
      The Aggressiveness Order of SMAT Products This might surprise you!
      It's a SMAT product.
      It's considered an AIO (All In One) meaning it has polishing/cleaning properties (swirl/defect removal) and LSP properties as well. If you want the best polishing and LSP properties then I would highly suggest using stand alone polish (i.e. M205) and a stand alone LSP (i.e. Ultimate Wax). This product is used for volume detailing where their main goal is getting cars in and out as quick as they can. It's not to be used for a show car type of detail.
      Hope this helps.
        mine falls into the trash catagory, never really works for me.
        I've tried it since it's been out but it's just not for me. 66 does a better job or just break out 205.
        DetailingByM.com
          I love D151! It could be the machine your using. I originally used a cyclo and it didnt seem to be very effective. Then i tried applying it with a Flex, HUGE DIFFERENCE. Then i tried my rotory, IT WAS AMAZING. This may be the most versitile product on the market. You can acheive so many things by changing pads, speeds, pressure, and machines.
          www.JaxDetails.com
          www.facebook.com/DentsAndDetails
          I may be slow, but I do poor work.
            Out here I seem to work on Pris cars quite a bit. I have found their paint to be soft. M205 will actually mar the paint and the PRC looks to be a good fit for that paint. I have a friend that put me onto the product and was just trying to find more uses for the product.My thought was to ask the collective and go from there. Thank you for your input and experiences.
              It has more cut then 205 if that helps.
              www.JaxDetails.com
                I heard lotsa guys having good results with PRC/MF pads...good AIO
                "STRIFE" aka Phil
