Can someone please tell me the main use for Last Touch spray detailer? Does it contain clay particles in the liquid and is it to be used between details or as a clay bar lubricant?
I believed UWWA has wax, Final Inspection has no silicon body-shop safe, Last Touch has silicon. You could also consider M135 Synthetic Spray Detailer which enhance wax protection.
How does UWWA compare to final inspection and last touch? I am trying it out as a detailer spray since the car is only a nice weather cruiser.
While you certainly can use UWWA as a quick detailer, it's pretty pricey when used that way. UWWA is a true waterless wash and can be used when the vehicle is actually quite dirty. As an example, I cleaned my weekend toy after driving it back from Las Vegas in a downpour and it worked beautifully. You can imagine how dirty the car was after 275 freeway miles in pouring rain, on a road that gets lots of truck traffic but hadn't seen any real rain in months. You would never use a traditional quick detailer on a car that dirty, but UWWA was designed just for this purpose.
For a nice weather only cruiser you certainly can use UWWA, but something like UQD or Last Touch is going to be far more economical. Then again, some of us here at Meguiar's have been so taken with UWWA that it's now our go to QD spray!
Mr. Stoops,
I am about to purchase LT as a replacement for UQD. How does LT differ from UQD and what is the recommended dilution ratios for claying and using as a detail spray? I am tired of making multiple trips to the store to buy more UQD and would like to use LT if it is as good or better than UQD. Please....anybody feel free to chime in if you have experienced using both products.
2010 F150 FX4 and 2001 Ford Escape
Meguiars All the Way!!!!!!!
I have not experienced both products cause I like Last touch so much with beautiful results. I almost don't need to use it anymore since I have been using the DA Microfiber system so I save on product so much. Speaking of, try Autodetailingsolutions.com Buy a gallon of the stuff. It's pretty reasonable and you don't have to keep running to the store. Good luck!!!
The direct replacement for UQD in bulk is M135 - same hydrophobic polymers, same slickness, etc. Last Touch does not have the hydrophobic polymers but it can be diluted 1:1 with water for use as a clay lube, or straight as a mist & wipe quick detailer. It has a very high lubricity formula so you can even get away with adding a few ounces to a couple gallons of water and using it as a rinseless wash in a pinch, although it's not nearly as effective in this use as D114 Rinse Free Express Wash is.
Last Touch is hugely popular because it's great stuff, but if you really want the hydrophobic polymers you'll need to go with M135.
I don't know about that polymers in the different products, and if you're looking to get a direct replacement for UQD, then I would follow Mike's advice in the above post. However, if you are simply looking for more economical way to perform quick cleanings and also use as a clay lubricant, I would highly recommend D114 Rinse Free Express Wash. I use it diluted at 1:128 ratio for my quick detailer (which is the recommended dilution ratio for using it as a waterless wash on dirty cars). I love the way it works, and I can literally get over 100 gallons of a quick detailer out of one gallon of RFEW, so for the price it absolutely can't be beat.
I use it quite liberally when washing cars since it is so economical, and at the same dilution ratio, it is also excellent as a clay lube. Plus you get it's original use as a rinseless wash if you have an even dirtier car and want more water. With this one product you can essentially get three different products.
I love Last Touch, but I am working my way through my last gallon and probably won't get any more simply because RFEW is such an adaptable product.
Last Touch is great stuff. It has good slickness, I find that upon first application, it feels slicker than UQD. UQD does feel tacky at first, after the 12 hour cure time as required in the instructions, it feels a bit slicker, there's still some slight tackiness to it, but it does "feel" tougher than Last Touch, and the water beads like it has some wax on the paint. The shine is a bit better with UQD, but Last Touch runs it very close
