Hi, I'm going to rub out my black Camaro after wetsanding with 2000 Unigrit paper. Is an 8oz. bottle of M105 enough? I'll be using a Griots Garage DA polisher. One other question, I already have 1200 3M wet paper can I start with that, then go to the 2000 Unigrit? Thanks for the help Mike
M105
Re: M105
Is this a fresh paint job? If not, 1200 would be too agressive on factory paint, even be careful with 2000.There isn't much clear on factory paint.
If it is fresh paint, i would start more agressive. I stared with 600 on mine to flatten out the urethane wave. I don't think an 8oz bottle will be enough. I used around 20oz or so, but i started with a rotary for the first cut with a wool pad, the used PC da for final cut of M105.
Re: M105
Originally posted by HVACPhil View PostIs this a fresh paint job? If not, 1200 would be too agressive on factory paint, even be careful with 2000.There isn't much clear on factory paint. If it is fresh paint, i would start more agressive. I stared with 600 on mine to flatten out the urethane wave. I don't think an 8oz bottle will be enough. I used around 20oz or so, but i started with a rotary for the first cut with a wool pad, the used PC da for final cut of M105.
Thanks,
