Today, I finally had the chance to use the much anticipated MF system. I had used the DA with UC & UP followed by NXt 2.0 with yellow and black pads respectively. That system works well as you all know, but some corrections can be stubborn and require time and much elbow grease. I washed the vehicles as always and then I began. The system I must say, is really quite impressive. The correction compound and wax in conjunction with the correct pads is a breeze to use. The correction process is amazingly fast. Compared to UC with yellow pads this is significantly faster.
The product removes with ease. The key is to clean the pad often. I used compressed air often, with excellent results. Less is best on the product side. I highly recommend this kit to any and all. You cant screw this up and the results make you look like a pro. You friends will be envious. I used the 5" pads which were really very nice and I recommend going no bigger. Good luck to all. It will be the best money spent. You will not be disappointed. I will snap a couple of pictures and see if I can figure out how to upload them.
