Question about DA MF System
  • Question about DA MF System
    I just ordered the system and it includes a bottle of M21. My question is where does the M21 go in the order of things? I thought that the D301 was a carnuba wax and should go on after the synthetic. So do I go with the D300 then M21 and D301 or should I do the D300, D301 and then M21?
    http://www.facebook.com/SuperiorDetails
    http://www.superiordetails.time2detail.com/
    Re: Question about DA MF System
    M21 Synthetic Sealant 2.0 is not a part of DA Microfiber Correction System but you could use it after D301 Finishing Wax as an extra coat of protection.
      I know it's not part of the system, but the kit I ordered included it as well.
      It has:
      - Meguiar's G110V2 Polisher
      - One Meguiar's W68DA Velcro Backing Plate For W9207 Foam Finishing Pad
      - One Meguiar's W67DA Velcro Backing Plate For Microfiber Discs
      - Two Meguiar's 5" Microfiber DA Cutting Discs
      - Two Meguiar's 5" Microfiber DA Finishing Discs
      - One Meguiar's W9207 Foam Finishing Pad (For Synthetic Sealant)
      - One Meguiar's D30016 Microfiber Compound (16 oz.)
      - One Meguiar's D30116 Microfiber Finishing Wax (16 oz.)
      - One Meguiar's M2112 Synthetic Sealant (12 oz.)
        D301 is a polish wax with some abrasives so it will remove the layer of M21 if you apply it first. You should follow the D300 with D301 then for your second coat of sealant use M21.
          What BS MXRacer said.
          You want to use D301 after D300 not only for protection, but also to remove any slight hazing that may have been left behind. You could stick with just finishing with D301, but if you want that little extra bit of protection, apply M21 on top of it.
          Remove swirls my friends.
            I just wanted to check. I figured that was the correct way to do it. I've just always used the synthetics before I used carnuba based waxes before and wanted to check if I could use the M21 and then use the D301, but I didn't think about the cleaning abilities of D301. Just had a brain fart I guess. Can't wait to get this in and get working with it. My folks took their car out of town and down a dirt road after I just detailed it for them the other day. Now it has scratches on it instead of just swirls. Can't wait to use this system on them.
