Meguiars D/A Microfiber Pads Quick Thoughts
  • Meguiars D/A Microfiber Pads Quick Thoughts
    I'm a long time reader and lurker and haven't ever posted on MOL (well once!), but I thought I would share some quick thoughts on the D/A Microfiber Pads.
    First some background... I'm not in the detailing biz, but have had a mild interest in detailing for the last 5 years. I've used both a D/A and a rotary. I've really only worked on my own cars (an 03 Accord, an 03 CTS and a 2010 Ford Flex) so I don't have tons of experience.
    I just so happen to be at the right place at the right time 2 weeks ago (the shipping truck was pulling in) and was able to pick up the Microfiber Pads at a retail location. Apparently, there was some mix up with the Meguiar’s shipping department since the retail location got the pads early (but not the liquids). As a result, I got to try the pads that evening at home on my 03 Accord. FYI, there could have been changes to the pads themselves or the packaging since I got these 2 weeks ago.
    Since there have been many other excellent reviews here, I’m just going to give a couple of observations and thoughts about the pads themselves. Bear in mind that I only have about 3 hours of use with these pads. Looking at the pads, the foam and the thickness are different between the cutting and finishing pads. The microfiber itself looks to be about the same on both pads. If the material is different, it’s difficult to tell. Since I didn’t have the liquids to go with the pads, I decided to try out the 5” cutting pad with M105. I’ve been using M105 as my go to product for the last couple of years so I’m familiar with it. This combination yielded some great results and easily corrected the same type of defects you would expect to correct with M105 and a Surbuf pad. But it was the differences that made this experience unique. Most importantly, the Meguiar’s Microfiber Cutting Pad was very dependent on the amount of pressure that was being applied and more pressure equaled more correcting ability. Where with the Surbuf’s I’ve found that light pressure is the only way to go with only one level of cutting. I didn’t try it, but I think it might be possible to apply very light pressure and achieve a great finish with the Microfiber Cutting Pad. The other difference from the Surbuf pads are no shreds of pad material all over your car! I used 1 Microfiber Cutting Pad during my 3 hours of use and the pad held up perfectly. I also threw it in the washing machine with my LC foam pads and pad came out just fine.
    Sorry I don’t have any pics of the car itself, but I figured the pads themselves would be more interesting at this point.
    Re: Meguiars D/A Microfiber Pads Quick Thoughts
    Cool! Aren't you lucky?
    Maybe I missed it but how did that combo finish out on the car?
    Tedrow's Detailing
    845-642-1698
      I only tried the cutting pads. I finished with an LC Tangerine pad and it turned out great. I'm going to pick up the liquids today and try the pads with the intended products.
        We kind of figured you'd chime in here, and thanks for holding off before doing so!
        Yes, this is a much "cleaner" system than the Surbuf experience, without a doubt. And if you think your experience with these pads and M105 was good, wait until you try the D300 Compound - virtually no dust whatsoever, incredibly easy wipe off, and almost the same cutting power as M105 with this pad.
        In fact, for casual D/A users who have struggled to get M105 working right for them, and/or who have just struggled to remove defects, the DA Microfiber Correction System will be a huge step forward.
          Are these pads replacing the regular yellow, black and burgundy DA Polisher pads?
            No, these are not replacing any of our foam pads. These microfiber discs were specifically engineered to work with the two new liquids in this system. If you had seen the back and forth tweaking going on in the development process of this system you'd be blown away. If we made a minor change to the thickness or firmness of the foam on a pad, we then had to alter the formulation of the liquid to keep things in "spec". Same if we altered a liquid a bit - something on the associated disc had to change, whether that was the microfiber composition, or something with the foam.
              Well I figured I would spread the wealth and offer up for free (1) 6" cutting pad to two people that want to try them and live around the 605 and the 91 freeways in Southern California. I don't have the liquids but you can try the pads with something else like M105. PM me with your phone number and I'll give you call and make arrangements for you to pick one up this afternoon. If you can't pick one up today, please leave these for people who can. Just make sure to post a review here on MOL!
                That is a really nice gesture!!!
                Bill
                  These were picked up yesterday so I hope we'll see some additional reviews.
