swirls re-appearing
First of all, I'm a big big fan of #80 not only because of cutting power but also because of the looks!
Here's what happened. I just finished polishing my brother's Honda Accord. I used #80 speed glaze on a W8000 polishing pad with a rotary. I've done this before so I'm not new to rotary with #80. (slow passess, medium-light pressure, then fast passess)
I finished it at around 10 in the evening with some halogen over the garage. It's 99% perfect. I did not use #83 since there were only minor swirls and from my evaluation #80 will do the job especially with my rotary.
I just left it bare after finishing and immediately went to sleep since it's already late at night. The following morning I pulled out the Accord into the sunlight since I need to clean the garage. For almost half of the day in the sunlight, it's left bare. At around 4PM I immediately parked the Accord inside the garage to start the finishing passes with #80 using the finishing pad. (before I hand-apply NXT)
But to my dismay, when I switch on the halogen lights, I noticed minor swirls re-appearing. I SWEAR, these swirls weren't really apparent the previous night or right just after #80's application.
Question:
Could it be just that I wasn't able to eliminate 100% of the swirls the previous night?
Am I just pushing #80 too much way beyond it's limit? (I use the rotary)
I'm more interested in the issue of re-appearing swirls, could it be just that the fillers in #80 evaporated when I left the Accord for almost half of the day in bright sunlight (I'm in a tropical country, and it's burning hot here.)
I know #80 is more of an abrasive polish and it does contain fillers because of the oil. My thinking was that, I may have eliminated "some" of the swirls while "some" were just hidden by the fillers, thus, reappearing the following day when the oils evaporated.
Should I use #83 instead to totally eliminate the swirls instead of filling? Does #83 contain less of the fillers in #80?
tnx!
Question:
tnx!
