Full Process Treatment
  • Full Process Treatment
    Recently, I'm finally accumulated all the neccessary products that I need to start my crazy habby. When I start reading this forum, I feel very confident. But when I practice it, I'm getting very confuse.
    I have the following products in hand:
    #85 #84 #83 #82 #80 #7 #20 NXT and #16
    Depend on defect I'll select between #85 and #84 but I prefer both with W7000 and not so heavy cut.
    #83 is the definite. everybody here should have atleast one in stock. For #83 I prefer using W8000 for first layer and W9000 for second layer. I'm a bit confuse here about how long should I wait to start thr second layer or following products?
    #82 and #80 is very confuse to me, I can't fugure out which one should go first. and how long should i wait to apply the next product.
    #7 is very liquid, I use Bosch E270 ROB at 2.0 and it is very difficult to dry.
    #20 I can't wait so long. I thinking to use a heat gun to dry it. is it possible?
    NXT, fantastic! so smooth. can I use heat gun to dry it so that I can shorten the 12 ~ 24 hours waiting time?
    #16, Wow! Marvelious! I have tested with heat gun. The layer getting very hard.
    Please correct me is my sequence ok?
    Re: Full Process Treatment
    Hi Mason,
    Welcome to Meguiar's Online!
    Originally posted by Mason
    I'm a bit confuse here about how long should I wait to start the second layer or following products?
    When you're working with Meguiar's compounds, paint cleaners, cleaner/polishes or pure polishes, here's the deal, you apply them, work them in, and then remove them. These product do not need to dry or set-up before removing and often times, the longer you wait to remove them, the more difficult they can become to remove.
    Only Meguiar's waxes need to dry before you remove them
    #82 and #80 is very confuse to me, I can't figure out which one should go first. and how long should i wait to apply the next product.
    #80 is more aggressive than the #82 and if you use one, you usually don't need to use the other. Choose and use one of these light cleaner/polishes after using a more aggressive product like a compound or the #83 DACP.
    Again, like I wrote above, when you're working with Meguiar's compounds, paint cleaners, cleaner/polishes or pure polishes, here's the deal, you apply them, work them in, and then remove them. These product do not need to dry or set-up before removing and often times, the longer you wait to remove them, the more difficult they can become to remove.
    #7 Show Car Glaze is very rich in polishing oils and does not really dry, nor is is supposed to. #7 Show Car Glaze is a pure polish so it fall into the category of products that you apply, work in, and then remove immediately. There is no reason to let this product dry. Only Meguiar's' waxes need to dry.
    I'm not sure what you mean here. #20 Polymer Sealant dries very quickly if applied using a thin coating. All Meguiar's waxes should be applied thin. In most climates they will dry to a haze, or be ready to remove in about 10 to 15 minutes, a little longer in colder, more humid weather. You don't need to dry our waxes with a heat gun.
    #16, Wow! Marvelous! I have tested with heat gun. The layer getting very hard.
    #16 is sometimes referred to as a traditional hard wax, it will set up very hard after it has fully dried. It is vitally important that when using this product that you apply whisper thin coats.
    All Meguiar's waxes should be applied thin. In most climates they will dry to a haze, or be ready to remove in about 10 to 15 minutes, a little longer in colder, more humid weather. You don't need to dry our waxes with a heat gun..
    Here's the basic order of steps to follow,
    Washing
    Before detailing your car, first do an extremely good job of washing it. Remove all the dirt from all the nooks and crannies. This prevents any small abrasive dirt particle from entering into the machine polishing process and potentially instilling a swirl. Get the Car Sparkling Clean to start with and everything will be downhill after that.
    Claying
    After that clay the car, at least the horizontal surfaces. Again, do a good job of claying to insure you remove all above surface contaminants. The level of gloss you can achieve from your car's finish is mostly determined by how smooth you can make your paint. Claying will make your car's finish as smooth as glass.
    Cleaning
    Cleaning is different than washing. Cleaning is removing both above surface defects like oxidation and below surface defects like swirls, scratches, etchings, and dirt that has embedded itself under the surface. Choose the appropriate paint cleaner for the condition of your car's finish and your application process. If you're unsure of which paint cleaner or cleaner/polish is right for your car, describe your car and if possible post a picture and we'll be glad to make some recommendations.
    Polishing
    Polishing after removing the defects is typically using a pure polish that is non-abrasive to restore brilliant high gloss and deep, dark reflections. This is an optional step and one best used on medium to dark colored car.
    Protecting
    This is where you apply your choice of wax or paint protectant. Adding a layer or two of wax creates a sacrificial-barrier on your car's paint to protect it and also add shine and gloss. Generally, two thin coats will insure even coverage with a uniform appearance.
    Maintaining
    Maintaining is the use of products like a quick detailer or a spray wax to maintain that "Just detailed look" in-between regular washings, and the regular application of a normal coat of wax.
    Meguiar's always teaches,
    "Always use the least aggressive product to get the job done"
    The idea is to see if you can restore an acceptable finish using the least aggressive product. Starting with a mild paint cleaner or cleaner/polish and testing to see what can accomplished with it is the safe way to learn which product you will need to safely remove the defects. If the first products you try don't do the job, you can always substitute a more aggressive product.
    The most aggressive you can go with Meguiar's products and a dual action polisher is using our #83 Dual Action Cleaner Polish and our W-8006 foam pad on the 5.0 setting. Getting any more aggressive than this can cause hazing of the finish and if the defects are serious enough to require a more aggressive product then you should use a rotary buffer or take it to a professional who is experienced with the rotary buffer.
    When it comes to removing swirls and other defects using the dual action polisher, here are two products that work really well,
    #80 Speed Glaze
    In keeping with Meguiar's philosophy of using the least aggressive product to get the job done, if you are unfamiliar with these products and/or your car's paint, then always perform "Test Spot" to a small are first before attempting to do the entire car.
    "If you cannot make one small area look good with your prescribed products and process, then you will not be able to make the entire car look good"
    Makes sense huh?
    To do a test spot, start out with the #80 Speed Glaze with a W-8006 foam polishing pad and buff for 3-4 minutes.
    When cleaning paint with the dual action polisher, you want to map out in your minds eye a section or area about 16" square or rectangle, or whatever fit's your car's body panels shape. The idea is you don't want to try to do to much of an area at one time or you will not get good results. The dual action polisher is gentle in it's cleaning and polishing action and for this reason, trying to work on too large an area at one time will not remove enough paint to remove any defects.
    Note: To remove a below surface defect, you must remove some paint until the highest points of the surface are level with the lowest depths of the defect you're trying to remove. This means removing paint. This also means how deep of a defect you can remove is determined by how thick you paint is. Often times you can improve a defect, but not completely remove the defect as to do so would remove to much paint and in the case of a clear coat, expose the color coat and in the case of a non-clear coat finish, you will expose the primer under the color coat. How much paint you can remove is hard to know because you can never know exactly how much working film-build you have to work with. Experience in this area helps a lot and sometimes luck is a factor to. Remember this, light swirls are generally pretty safe to remove, but deep scratches like key scratches etc. you will probably be better off merely improving the way they look so they don't stand out like a sore thumb, the to attempt to completely remove them.
    When using the dual action polisher to remove defects, map out a section to work in your minds eye. Check the speed setting on the variable speed adjuster. For removing defects you usually need to be around the 4.5 to 5.0 setting. Meguiar's never recommends running the polisher faster than the 5.0 setting as these higher speed settings produce an oscillating action that is too violent in it's speed and motion and this combined with time creates heat and the synergy of all these factors will loosen the Velcro material attached to the foam. Keep your speed settings at 5.0 or below.
    After applying some product to your foam pad, (already attached to the polisher), place the face of the foam pad onto the finish and then turn the polisher on. DO NOT turn the polisher on before it has come into contact with the foam pad or your will sling product all over the place and then you'll get to clean the splatter up instead or work on your car's finish. Once you have turned the polisher on, move the polisher around to spread out your product over the area you are going to work. This is important. What you're trying to do here is to spread-out your product so that you have a film of fresh product spread out over the surface you're going to work. THEN begin to work the product against the finish using a slow arm speed, moving the polisher back and forth over the section and overlapping your passes by 50%. You should run the polisher in a couple of different directions, always with overlapping motions, to insure even cleaning over the entire surface.
    Note: The reason you want to spread your freshly applied product out over the section you're going to work is because if you turn the polisher on and immediately begin to work in one place, as you're working the product against the finish the diminishing abrasives are breaking down. As you continue to move around the area you're working, by the time you get to the last portion of the area you're working, you will be using a much less aggressive product than when you started out because all the while the diminishing abrasives have been breaking down. If when you first start out you take a few moments to spread the freshly applied product around over the entire section you're going to work, and then go back to your start point, you will have fresh product ready to be worked into the finish as you move from one area to the other.
    Does that makes sense?
    After you have buffed the area for 3-4 minutes, (how long you buff can be relative to the temperature and humidity in your area, also the type of paint your working on and the amount of product you applied. The important thing is that you buffed long enough to work the product against the finish and have broken the diminishing abrasives down, but you have not buffed to long and buffed to a dry buff. This is something that is hard to explain with a keyboard and a computer monitor and is really something that first-hand experience will teach you), stop buffing, wipe off the residue and inspect the results in two kinds of light, (if possible). If your results look good and are acceptable to you, then repeat this process, (#80 Speed Glaze with the W-8006 foam pad on the 4.5 to 5.0 setting), and after removing all of the residue you can then go on to the waxing step.
    If your results don't look good, and this combination of products is not removing as many of the swirls and scratches as you would like, then try repeating the above to the same test section using the #83 Dual Action Cleaner Polish. Use a new clean W-8006 foam polishing pad for this step, or a W-8006 foam polishing pad that you have previously used with the #83.
    Here's a suggestion
    Use a permanent marker to mark the back of your buffing pads with the product number you're using with them so you don't mix different products onto different pads.
    After buffing the test section on the 5.0 setting remove the excess product and re-polish the same area with the #80 Speed Glaze and the W-8006 pad marked and used with this product. Repeat the same procedure as originally outlined for doing the test spot with the #80 above. After you are finished buffing this area, remove the residue and inspect your results again in two kinds of light if possible.
    The goal of coarse is that now your car's finish will look great! and be ready for you choice of wax. If your car's finish does look great and meets your expectations then repeat this 2-step cleaning approach to the entire car. If not then chances are very good to remove the defects and meet you requirements the finish will need to be professionally cleaned and polished using a rotary buffer by an experienced professional.
    Hope this helps...
      Thanks Mike, You are very fast to response. Do you mean that I can apply only either one of #82 or #80? Is it possible to apply both?
        Hey Mason,
        Yes you can use both if you want, you just may not need to depending on how your paint responds to the #80 Speed Glaze. With some paint, #80 will remove the swirls etc. In that case you can go directly to the sealant/wax step. If however, after the #80 some light swirls still remain, you can then follow the #80 with the #82.
        Tim Lingor's Product Reviews
          Thanks Mike and Tim. Both of you are very knowledgeable and professional in this specialise area.
