Dilution Ratios of SD
  • Dilution Ratios of SD
    Would a dilution ratio of 10:1 for SD be strong enough to handle moderately dirty tires? I would think that it would but I want to make sure.
    When would you use the 4:1 ratio? That seems like it would be for heavily soiled engines and such but I want to make sure.
    Tedrow's Detailing
    845-642-1698
    Re: Dilution Ratios of SD
    You can always try 10:1, and if for some reason it doesn't work, add a bit more concentrated SD to it and try again. It's hard to say a certain dilution of a product will for sure work on ________. That being said, I think SD at 10:1 should work fine for your "moderately" dirty tires. Just make sure you wet the wheel and surrounding body panels well, maybe even putting some soapy water on them too (I do that on my Mustang to be extra safe; I think Tim gave me that tip).
      How to properly dilute Meguiar's Detailer Line products
