Super Degreaser and APC+?
  • Super Degreaser and APC+?
    I have a gallon of APC+ already. It just came last week, and I haven't used it yet, so I don't know if it will suffice, or if I'll want a little more degreasing power for engines and wheelwells. Am I also going to want some SD?
    Re: Super Degreaser and APC+?
    Depends how bad things are.
    APC+ can certainly do a lot, esp wheelwells, tires, etc. No reaon not to try it first.
      Since you already have it. Go with the apc+ first. Remember you can adjust the levels of concentrate. From 10:1 all the way to 4:1. You just might need a stronger batch.
        APC+ should plenty suffice for wheel wells. Engines are too hard to generalize, but as long as they aren't covered in oil and grease, APC+ should be fine as well. That's what I use on my engines.
          Most of the plastic covers on the top of engines will only need APC, usually the engine block and around the firewall will be where the really nasty stuff hides. May need the Super Degreaser there.
            I just received the Professional Sampler Kit from ADS - I was wondering the same thing. I have yet to detail the engine bay due to the temperature and weather outside. Hope to try it out soon! Let me know how yours goes!
