polycharger M16 , aham ...
  • polycharger M16 , aham ...
    well got 5 tins of M16 wax... and i was thinking why not mix with some polymer booster , polycharger!
    i took one tin , put it in water on cooktop and when was melt i did some math and add polycharger ch2 and start mix.
    one tin 11 oz, for each oz of wax, u add 2 measure of polycharger ch2. easy!
    didn`t cheese or anything like that looks like it mix well. i put the tin on side and now is in the fridge to get level and solid.
    i will see in the morning how it looks and i may do some test soon.
    i use polycharger with klasse and works great.
    it should improve m16 duration , may help a little in easy on easy off, and should give more "glass" in overall look on car.
    pic sooon ...
    proreflection
    *Ceramic Coating * Protection Film * Car Wrap * Paint Correction
    Detail Luxury and Exotics in Austin area
    Re: polycharger M16 , aham ...
    sounds interesting... the creativity of MOL never ends :]
    Ganesa,
    Toyota Vios '05
      I'm excited to hear the results. This may be good.
      Colin
        That tin might go bad pretty soon. Polycharging a product reduces its shelf life dramatically. You are only suppose to mix what you are going to use. Products that come polycharged from production are different(example: Ultima PGP, 4* UPP). Direct from polychargers website.
        "Do not mix more wax than you plan to use in 48 hours. After two days a boosted wax mixture must be thrown away, as the wax will thicken or harden in the bottle."
        Alan T.
          I too will be interested in how the polycharging improves the durability of this. Keep us posted.
            well are more online if doesn`t hold. the tin after 8 h fridge is a little softer than regular.
            on weekend i may test it if stay till than.
            proreflection
              Perhaps thats only a concern with liquid products
              VTEC: all the lag, none of the turbo
                i took the tin out of fridge in the morning and by evening is was a light paste , is more like a liquid, i may put it in a bottle. m16 looks green
                i apply one coat on my car but just tomorrow i see the result , got dark on me. i remove it with onr in clay-lube dilution to speed up the process.
                not sure if will be a good test because in weekend i just put some klasse SG on it , so i may try on a different car to see the result , but i may take a pic tomorrow and post , i saw a improvement.
                proreflection
                  This gives me an idea... SwirlX mixed with M16... maybe a drop of UC to spice things up! Instant cleaner wax! lolol...
                    PICTURES update
                    here is the "paste" , 70% of it is liquid , and some 30 % is paste .
                    car has been klasse sg few days ago so it may not be a good test , but after m16 i think is more darker than with sg only.
                    proreflection
                      The Passat looks pretty good there.
                        I think it's an Audi A6, not a Passat. If what others say is true about the PolyCharger shelf life, I'm sad to see the wasted product. A tin of M16 should last many, many applications.
                          will see , i may put it in a nxt2 empty bottle , is more liquid than paste , and i see i have to agitate the bottle to use it. also air will be limited when open to get liquid out.
                          proreflection
