About #105 and D151
  • About #105 and D151
    Hello there I'm a new member in MOL, I would like to ask something about 105 and D151....
    I've been recomend by my friend about 105 and D151...waht product should I choose between 105 and D151 if I want to detail a car that hasn't been detailed for years and want to have a flawless and perfect clear finish, BTW I'm using rotary....please help me to decide thx for the answer before.....and nice to know you all
    PS: sory if my english really bad i hope you'll understand
    Re: About #105 and D151
    I use D151 a lot more than I do M105. But it all depends on the condition of the car and how much time you have.
    AeroCleanse, LLC
    www.aerocleanse.com
      M105 is a compound, need to follow up with polishes like M80.
      D151 is AIO product which contain cleaner, polishes & wax.
        Actually you should be able to finish off M105 with D151 depending on pad choice. D151 on a foam finishing pad finishes off very nice.
        What pad will you be starting with?
        M205 would be a better product to finish off with, but D151 should work well too.
        Rasky's Auto Detailing
          What do you want to achieve from your work? If the car hasn't been detailed for so long, especially you live in Indonesia, I think you need #105 and you can finish it with #80 or you can wait until #205 available in Indonesia. But if you want to do routine maintenance for your car I think d151 will be wise option.
          Polishing is an art!!
            M105 is an aggressive cutting compound for removing serious paint defects
            M205 is a finishing polish for use after M105 to work the finish up to a clear, swirl-free high gloss.
            D151 is a one-step, all-in-one cleaner/wax. It's nothing like either of the two above products.
            I've been recommend by my friend about 105 and D151...waht product should I choose between 105 and D151 if I want to detail a car that hasn't been detailed for years and want to have a flawless and perfect clear finish, BTW I'm using rotary....please help me to decide thx for the answer before.....
            If you want a show car finish on car that's been neglected for years then you here's a proven formula...
            M105 with a wool cutting pad on a rotary buffer at about 1500 RPM
            M205 with a foam polishing pad on a rotary buffer at about 1500 RPM
            Wax or Paint Sealant of your choice usually applied by hand or with a DA Polisher or an Orbital Buffer.
            Read this thread for why not to apply a finishing wax with a rotary buffer.
            Applying Tech Wax 2.0 or M21 with a rotary buffer?
              i'll be starting with megs foam polishing pad...how about finish M105 with M80 speed glaze...because here ini indonesia this 2 product quite expensive (M105 and D151 ) now I have M80 and M83...
                thx mike for the answer that's really helpfull...you said M105 with wool cutting pad work really well...how about foam cutting pad with M105? does it work well to?
                I still waiting for M205 can be purchase in indonesia
                  I
                  Yes, it works very well too. Personal preference.
                  I used to use mostly foam cutting pads and avoided wool pads unless removing wet-sanding marks out of a wet-sand, cut and buff job, but with M105 and a wool cutting pad you can remove defects very quickly and work the finish up to about 90% of a show car finish so the other 10% is easily done with M205
                  Personal preference but both wool and foam cutting pads work great with M105
                    ok thanks mike i think I will get the M105 soon and will post the result here thanks a lot
                      I have a stupid question pop up in my mind ....how about I'm using M105 with polishing foam pad? is it going to work? what will happen? i mean does it gonna make micro marring or hologram maybe thx sorry if this question is really stupid
                        Yes it will work. Usually if you're using a heavy cutting compound like M105 it's because you're trying to remove serious paint defects and if this is the case you would usually use an aggressive pad, either wool or foam.
                        But the answer is yes, you can use M105 with a foam polishing pad like our W-8006, W-8000 and W-8207
                          thank you mike...i'm just curious that's all, btw thanks for all your reply I've already ordered a bottle of M105 and today i hope i got the product
