With the one gallon containers of their new pro detailer line, should you use distilled h2o when you mix with the product or is regular water ok?
Distilled h20 with pro products
There are many variables to this answered
Yes plain tap water should be fine BUT you would need to know some thing about the water you are using.
Is it city or well water?
City water goes through some filtering process before it gets to you, They also use to add fluoride and potassium carbonate to the water depending on the Ph before treatment. Not sure if these chemicals should effect you since they are in such a small quantity.
Well water would be a guessing game, you really never know what you have unless it was tested.or if by some chance you have a water softer system in your home then all would be fine.
As for using distilled water it could become some what costly. but not a bad idea.Rich
If you don't have Meguiar's in your hand
DON'T TOUCH MY TRUCK
