In another thread I wrote about getting a tin of the mythical #16 paste wax.
I had the chance to use it today. I wish I had pictures buy my wife was at a party with the camera.
I used the wax on a 2003 Taurus with Grey metalic paint (it has a mediaum color, not dark and not light) 5 weeks ago I washed, clayed, polished with #9-2.0 swirl remover and waxed with NTX 2.0 liquid. 4 weeks ago I waxed the horizontal surfaces with Gold Class paste. Since then the weather hasn't cooperated and I have done nothing.
Yesterday I did a full (very needed) wash with Gold class soap.
I then pulled out the #16 and waxed the entire vehicle except for 1/2 of of the hood. I had read multiple times where thin coat had to be used or you wouldn't be able to remove the wax. I also read the thread about twist your applicator on the wax and that will be enough.
I will say that I was shocked how easily the wax went on. Because the tin is new and flat I couldn't spin the applicator but found that If I lightly swiped it across the tin I had more than enough for a 3X3 area. I would guess that this tin will last me forever at the rate of usage.
Here is where the problems start. I went to the where I started waxing and it looked like it was ready to be removed but with the swipe test only a little on the top came off. So I tried a small area anyway since it was 30 or more minutes, but it seems like it needed to cure more. I did some other stuff and then started to remove the wax even though it was acting the same way.
The wax was extreemely hard to remove. I don't think it was because i put the wax on to thick. I actually found in the spots where it was a little thicker it came off a little easier. But, in no way was it easy to remove anywhere.
After taking maybe an hour to remove the wax, I pull the car back so what little sun we had could hit the hood. I couldn't see anything different between the side with #16 and the side with 4 week old GC.
Not wanting to give up and put another thin coat on the entire hood and the roof. I let it cure for at least 45 minutes and then removed it again. It was still very difficult to remove but I thought maybe it was a little easier.
So in the end after reflecting on my experience I can't see why this is so special. The shine was nothing better than GC or NTX. Putting it down was maybe a little easier, but not much. Removal was a complete pain in the rear. It probably took me 4X as long to remove the wax, with 10X the effort. I really wanted to love this. I really had hoped it would make the car pop more.
One last thought I had was the temprature was pretty low. It was mid 50's. I have found that NTX doesn't seem to like to be applied in colder weather could #16 be similar.
So please tell me, is this what I should expect with #16? Is it going to make my Black Excursion look great (I can't imaging removing the wax by hand on that big of a vehicle)
