safe-d-greaser??
  • safe-d-greaser??
    Hey all,
    Just wanted to know if Meguiars Safe d Degreaser is safe on paintwork or not??
    Re: safe-d-greaser??
    Originally posted by buddy89 View Post
    Hey all,
    If you mean safe as in it will not stain paint work then yes it is. I use it with a foaming sprayer to spray down the lower 1/3 of the cars I detail to pre-soak the area to help remove road grime. I also spray the frontend also to help soften he bugs that get stuck onto the paint.
    Andrew
    2013 Race Red F-150 SCREW
      Safe-D-Greaser has been discontinued, you still may be able to find it for sale and if you do and you want some then you may want to pick up a gallon or two.
      In the Professional Line forum, there is a thread Meguiar's New Detailer Line, which lists all of the products in the Detailer Line and their dilution levels.
      While Safe-D-Greaser is formulated to be reduce the potential for staining exterior surfaces such as painted panels, a good safety precaution is to either wet these areas down with soapy water and keep them wet while using this product or tape-off these areas with plastic.
      Today's vehicles utilize a variety of specialized materials, which is why Meguiar's Safe D-Greaser has been specially formulated to reduce the possibility of staining exterior surfaces. Designed to quickly break down grease and grime on engines, tries and fender wells, Safe D-Greaser is ideally suited for today's fast paces, high volume shops.
      D-10501 1 gallon
      D-10505 5 gallon
      D-10555 55 gallon
      Dewaxing 20:1
      Medium Duty Degreasing 10:1
      Heavy Duty Degreasing 4:1
      Recommended replacement for regular All Purpose Cleaner and Citri-Gel Multi Cleaner.
        Andrew
        hey Andrew,
        I have a gallon of this product, but have never used it in a foaming sprayer for presoaks, do you find it more effective than say APC?
        Tom
          Originally posted by Tom Weed View Post
          hey Andrew,
          Tom
          To build on that question... Tom, do you use APC as a pretreat? What dilution and about how long do you let it dwell? Also, APC or APC+? Thanks!
          Scott
            hey Andrew,
            Tom
            Tom,
            Unfortunately I have never used APC or APC + for anything on the exterior. I can say that Safe-Degreaser is very effective at removing wax,road grime,grease, and bugs from my vehicles and all vehicles that I have detailed in the past. When I have used it I mix it inbetween 10:1 and 20:1. If the body panels are realy nasty I go with 10:1. The area first gets wetted down and sprayed I let it sit for about 2-5 minutes before washing it off with a dedicated wash mitt. The paint comes out squeaky clean with nothing left on the surface. I would have to say by it being a degreaser that it is stronger than APC or APC+ so in my thinking it would be more effective than either of those 2 products if mixed the same and being used for the same type of job.
            Andrew
              Tom,
              Andrew
              Thank you Andrew!
                Scott,
                Yes, I do use APC to pre-treat a customers car depending on the condition it's in, if I am using a spray bottle, it would probably be at 10:1. When I had a Karcher pressure washer, I used the foam attachment which really made a lot of foam, but not sure the dilution ration, maybe filled the sprayer 1/3 of the way full? I don't have that anymore and now have a Campbell Hausfield which has two solution tanks, one I will fill up to 1/3 full with Hyper Wash or whatever soap I am using, the other, 1/3 with APC. Whichever one I am using to pretreat is dependant on what I am working on and how dirty it is. Using this machine though does not create near the foam that my karcher foaming attachment did though. I use APC, I tend to save my APC+ for interiors and carpets due to it foaming less.
                If the car has a lot of tar or grime on it, I will pretreat that area in a spray bottle with Body Solvent before washing it as well.
                As far as dwell time goes, I've never really even given it much thought, by the time I spray down the area, get my stuff ready for washing then I am good to go. I would say that I don't want the presoak to dry on the vehicle. These methods are only for dirty cars I am detailing. For a car that is in good shape and that I will not be buffing, then maybe a pretreat with your favorite car wash soap to losen up any grime. Hope that makes sense and I didn't ramble on too much...
                Tom
                  Great info Tom! Thanks much!
                  I'll have to give that a shot next time. The lower panels on the Jeep get pretty nasty.
                  Scott
                    For future reference and ease of locating this thread has just been tagged with...
                    Safe-D-Greaser
                    You can now find this thread by looking in the "Popular Tags" box on the forum homepage.
