A guy I know told me he used APC for stripping wax from cars, thought i´d run it by you guys before i tried it.?
APC for on painted surfaces?
1996´AUDI S6 AVANT QUATTRO
00`S6 tip 92´S4q, 97´S6q, 97´A4q, 02´A4q, 76´ Audi50Tags: None
Re: APC for on painted surfaces?
Originally posted by BlueZero View PostI 'think' on the bottle there is a dilution listed for stripping wax. I don't remember what it was.
Edit: Or maybe that was Safe D-greaser. Hmmm
Mike, you around?Arctic Detailing - Northern Norway
I don't think thats on the bottle... I have one at home but not at work!?!?Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
I think that was on Simple Green...
Either way, it is kind of like Dawn... doing it once or twice wouldnt hurt anything, but why would you want to? There is no need to "strip" wax, just give a car a good detail and it takes car of itself.2017 Subaru WRX Premium - WR Blue
Safe D-Greaser
Today's vehicles utilize a variety of specialized materials, which is why Meguiar's Safe D-Greaser has been specially formulated to reduce the possibility of staining exterior surfaces. Designed to quickly break down grease and grime on engines, tries and fender wells, Safe D-Greaser is ideally suited for today's fast paces, high volume shops.
D-10501 1 gallon
D-10505 5 gallon
D-10555 55 gallon
Dewaxing 20:1
Medium Duty Degreasing 10:1
Heavy Duty Degreasing 4:1
Note: We discontinued that product so let me check if there's a substitute...
Also...
Using a paint care product like a paint cleaner or a cleaner/polish to remove any previously applied wax has the benefit of removing any defects while leaving the paint clean and shiny.
Using a degreaser to chemically strip any previously applied wax will then to leave the paint duller than when you started.
We usually try to teach people to move forward in the paint polishing process and that means each step should be making the paint look better and better...
Originally posted by Mike Phillips View PostNote: We discontinued that product so let me check if there's a substitute...
Like others have said there are better options. Although I guess it would be the quickest way.Scott
I have found super degreaser to stain some paint finishes. I stay away from using it on paint. And from my understanding is that the use of APC on painted surfaces will over time jepordize the paint resins and cause premature paint failure and oxidation.
Opinions?
