M105 Pad Question?
  • M105 Pad Question?
    Hello all,
    I was wondering what types of pads are recommended for use on the rotary with M105 can a standard W8006 pad be used with it?
    Re: M105 Pad Question?
    I have used the So1o wool pads with M105 and they work well.
    -Bob
      M105 is an aggressive compound designed and formulated to be used with a wool cutting pad. Some people have tried it with foam pads and had good luck with the results but it's definitely something you want to do a Test Spot with before going over the entire car.
      Here's some threads to check out...
      M105 Ultra Cut Compound - New (http://meguiarsonline.com/forums/showthread.php?t=20650) M105 Ultra-Cut Compound Exclusive, super-micro abrasive technology FEATURES: • Ultra-fast cutting removes 1200 grit or finer sanding marks • Super-micro abrasives leave best in class finish • Also great for
      Here's Tim's aka 2hotford very thorough review, a good read to the last page.
      **New** Meguiar's #105 Ultra Cut Compound Review!!!! (http://meguiarsonline.com/forums/showthread.php?t=21694) Hey Everyone, One of the hardest parts in detailing is removing swirls, and scratches in scratch sensitive or very hard paint. Some vehicles have paint as hard as glass! You can buff with a Dual Action
      Here's a common question about M105 which we're going to move to "Hot Topics" right after we submit this reply.
      Can M105 be used with a Dual Action Polisher like the G110, or the G100/PC or the UDM
      Here's a quote from the above thread...
      M105 can be used with a foam cutting pad on a rotary buffer. It is optimized for use with a wool cutting pad on a rotary buffer but can be used with a foam cutting pad on a rotary buffer.
      Remember the market this product is designed for and formulated for and that's the body shop industry where typically guys are sanding down fresh paint and then removing their sanding marks using a wool pad on a rotary buffer.
      And here's another great thread on pads and M105
      Hi Everyone, Could the Ultra Cut Compound - M105 be used with the Cut 'N Shine® Wool Pad? or it should be paired with the new Double Sided Wool Cutting Pad? is the new Double Sided Wool Cutting Pad be used with the old 8" backing plate? Another thing is, I found that the M21 2.0 has been removed from the estore in
      Hope this helps...
        Thanks guys that helps a lot
