Quick Reivew:
M105 is simply the best compound I have used and is extremely versitile.
Compared to: Menzerna Power Gloss and 3M Extra Cut on White/Orange/Yellow/Purple Wool/Meguiars Solo Wool Light/100 Percent Twisted Wool.
We tested this polish vs. two of my favorites to see what how it stacked up. We also used a varity of pads to test the finish left behind, and wiped the finished surface with DuPont Prep-Sol to ensure all oils had been removed.
M105 simply cut more and faster then the other two (with PowerGloss being the slowest) and leaved the finished surface far nicer then the other two with each pad tested. It was the only product that fully removed 1500 sanding scratches on one pass (with a full wool) vs. two for Extra Cut and our for Powergloss.
We finished polishing with 3M Ultra Fina on a blue pad. With 3M Extra Cut as well as Powergloss on each of the wool pads, the finished required a middle step of Menzerna SIP on a LC White Pad to remove the marring before being able to be finished to perfection. On the Orange Pad and under Power Gloss was able to be finished out where as 3M Extra Cut required a third step on any pad.
M105 was also able to remove moderate marring on a white pad while finishing marring free (though it did leave hologramming that still required a second step).
It really worked well on a LC Purple paint on several different paints we used it on, as it removed most defects and left the surface ready for a final jeweling to ensure perfection.
The downsides are that using two much product will result in the product gumming up as well as the pad will "load" with product rather quickly. Once this happens, it will begin to gum up as well. So make sure you use a small amount (three SMALL dots, about half a dime or so each).
