Whats the difference between the Professional Last Touch, Sythetic Spray, Final Inspection, Nxt Speed, Ultimate Quick detail spray???????????
Difference between all Megs Detail Sprays?***
Re: Difference between all Megs Detail Sprays?***
I know some differences, etc., but probably not enough.
IDK why people expect an answer within a very small window of time on a question like this. That is a lot of information to put out there. You posted it at 4PM on Sunday afternoon, and wanted an answer by 1AM (Monday morning when people have to go to work). Give it some time.
Behind the scenes we have a lot of other project to do and to compile an explanation for a topic like this will take too much typing time.
Suffice to say, all these products are in the same category, that is they are "Mist & Wipe" products. They all remove,
Light Dust
Fingerprints
Smudges
We're sure all of them will do the above for you on your car and the new UQD will make your paint the slickest and make the water bead up really well.
Which ones have you tried in the past if any?
Originally posted by roushstage2 View PostI know some differences, etc., but probably not enough.
Originally posted by Mike Phillips View PostBehind the scenes we have a lot of other project to do and to compile an explanation for a topic like this will take too much typing time.
Light Dust
Fingerprints
Smudges
Originally posted by VonLego View PostTo my understanding UQD leaves a residue, which to me would make sense not to use it prior to waxing.
Andrew2013 Race Red F-150 SCREW
Originally posted by funkdoktor View Postjust the speed detailer...i was thinking about the last touch spray detailer because it comes in the gallon.....final inspection comes in the gallon also right?....hmmmm....which ever one comes in the gallon is the one i want...and if there is more than one that comes in the gallon...imma pick the cheaper of the bunch.....thanks again fellas...
The difference between Last Touch and Final Inspection is Final Inspection is Body Shop safe where as Last Touch is not. In my opinion, Last Touch leaves a better shine, a little goes a long way but it tends to want to streak in the humid months. Last Touch can also be diluted 1:1 for claying as well. Last Touch used to be my go to detail spray, but now I've turned to UQD or 135 in the Pro line because of the glossy finish they leave behind. I believe UQD and 135 are not recommended for claying though.
Tom
P.S. Body shop safe means if you were going to paint, the Last Touch would leave behind something on the surface that would cause an issue with the paint to bond to the surface, where as Final Inspection would not, thus not being a body shop safe product.
In my humble experience:
Quik Detailer: removes [light] dust, fingerprints, light water spots prior to waxing. Use it as a lubricant for claying. Available in an aerosol can which is proving to be popular.
Ultimate Quik Detailer: Use it to maintain between waxing after drying car (usually next day). Has great results and water really beads up. Something about hydrophobic polymers that even the best Mothers spy couldn't get out of the chemists at Meguiars.
NXT Speed Detailer: I find the results in my experience slightly similar to UQD but use it after washing and drying too (found it on sale and using it up, have 3 bottles of UQD after that). Has good results, use it for what mood I'm in.
Sorry I have not used the Mirror Glaze or Proffesional series although you could look at each of the product descriptions. The Synthetic spray has similar results as Ultimate Quik Detailer or word on the street \/\/oRd!
Synthetic Spray Detailer
Final Inspection
Last touch - Comes in a foam too!
The Professional Series and Mirror Glaze series are aimed at pro shops/detailers as they availability in larger size quantity and the UQD, QD and NXT are available at most stores.
Hope that helps a little.
AaronPhilippians 2:14 - Do all things without grumbling or questioning,
funkdoktor- it's cool. I was just pointing out it may take a day or two. Good question though, been curious myself, just never thought about asking.
Never bought into the body shop safe stuff. Any good quality body shop prepares the vehicle correctly and does not have a problem. I really don't think thats an issue. We had some stuff painted a year ago thats was black on the Ford Escape , there wasn't anything body shop safe on there , my son painted it and never had a problem , but he knows how to prep.
