Ok, I called for the new pro catalog today and I'm going to be on the edge of my seat for it to arrive next week. In the meantime, could anyone share any more info, pics of the new Detailer products?
The new Detailer Line
Tags: None
This was originally posted by rjstaaf on Autopia, thank you rjstaaf!
Here are the part numbers, names and blurbs from the new detailer line out of the new professional catalog. If you need detailed info on any of the products Mike or Meguiar's customer service is probably your best bet.
Super Degreaser - Meguiar's Super Degreaser exceeds expectations by quickly breaking down even the toughest grease. Its fast acting, free rinsing formula prevents unsightly white residue stains while its herbal fragrance creates a pleasant work environment.
D-11501 1 gallon
D-11505 5 gallon
D-11555 55 gallon
Dewaxing 20:1
Medium Duty Degreasing 10:1
Heavy Duty Degreasing 4:1
Safe D-Greaser - Today's vehicles utilize a variety of specialized materials, which is why Meguiar's Safe D-Greaser has been specially formulated to reduce the possibility of staining exterior surfaces. Designed to quickly break down grease and grime on engines, tries and fender wells, Safe D-Greaser is ideally suited for today's fast paces, high volume shops.
D-10501 1 gallon
D-10505 5 gallon
D-10555 55 gallon
Dewaxing 20:1
Recommended replacement for regular All Purpose Cleaner and Citri-Gel Multi Cleaner.
All Purpose Cleaner - Meguiar's All Purpose Cleaner is ideal for reconditioning interior surfaces. The superior foaming action gently lifts the dirt away while its unique blend of fabric softeners and optical brighteners enhance the look and feel of carpet, upholstery, vinyl and even leather.
D-10101 1 gallon
D-10105 5 gallon
D-10155 55 gallon
Recommended replacement for All Purpose Cleaner +.
Hyper-Wash - Typical dilution rates are obsolete when comparing them with Meguiar's Hyper-Wash. Using innovative techniques Meguiar's has created a product that produces rich, stable foam at an unbelievable dilution rate of 400:1 (yes 400 that is NOT a typo). Its biodegradable formula safely and effectively lifts dirt and grime off all surfaces.
D-11001 1 gallon
D-11005 5 gallon
Dilution 400:1
Recommended replacement for Car Wash Soap.
Shampoo Plus - Meguiar's Shampoo Plus lubricating formula and luxurious foam team up to gently clean and condition even the most delicate clear coat surface without scratching. Its conditioning formula deepens gloss, boost shine and leaves a highly reflective, slick surface making it the perfect choice for the ultimate car wash.
D-11101 1 gallon
D-11105 5 gallon
D-11155 55 gallon
Dilution 10:1
Recommended replacement for Wash 'n Wax.
Glass Cleaner Concentrate - Our Glass Cleaner Concentrate easily and consistently removes tough vinyl fog residue, road grime, smoker's film and bug splatter, producing crystal clear glass. For every concentrated gallon, you get eleven ready-to-use gallons of glass cleaner.
D-12001 1 gallon
D-12005 5 gallon
Dilution 10:1
Wheel Brightener - Meguiar's Wheel Brightener is the product of choice for professionals looking for a powerful wheel cleaner that quickly and effectively removes tough brake dust. There is a thin line between effective cleaning and dangerous to use products. Wheel Brightener gives users the ultimate in flexibility, cleaning and safety with one product.
D-14001 1 gallon
D-14005 5 gallon
D-14055 55 gallon
Dilution Up to 4:1
Not for use on anodized, magnesium or polished aluminum wheels.
X-Press Liquid Wax – Meguiar’s X-Press Liquid Wax uses a unique blend of wax and polymer agents to produce deep, rich gloss with lasting protection. This formula provides ease of application and instant wipe-off, making it the perfect choice for any production environment where Meguiar's quality results are as essential as speed & efficiency.
D-15001 1 gallon
Ready to Use
Application hand, orbital, DA or Rotary
Recommended replacement for Express Wax.
Last Touch - Meguiar's Last Touch Spray Detailer produces incredible depth, shine and gloss. This spray-on, wipe-off product has a unique blend of polymeric lubricating agents that gently removes dust, fingerprints, smudges and other contaminates, leaving a flawless, showroom shine.
D-15501 1 gallon
D-15505 5 gallon
Ready to Use
Can be used as a lubricant for Meguiar's clay, dilute 1:1 for this application.
Recommended replacement for Final Detail
Body Solvent - Meguiar's Body Solvent changes the traditional method of removing tar, road grime, gum and other petroleum based substances. Instead of applying and scrubbing, its VOC compliant formula can now be sprayed on the surface, allowed to soak, penetrate and break down the contaminant, then wiped clean with ease.
D-13001 1 gallon
D-13005 5 gallon
Ready to Use
All Season Dressing - Meguiar's All Season Dressing is a VOC compliant formula that produces a deep, rich, long lasting shine on all exterior rubber and plastic surfaces. Old or new, weathered or worn. All Season Dressing will give you the desired results time after time.
D-16001 1 gallon
D-16005 5 gallon
D-16055 55 gallon
Ready to Use
Recommended replacement for S-Dressing.
Silicone-Free Dressing - Meguiar's Silicone-Free Dressing is the choice for professionals looking for a high performance dressing which can be used in any silicone sensitive environment. Its VOC compliant formula produces an incredibly deep, rich high gloss shine on all exterior rubber and plastic surfaces.
D-16101 1 gallon
D-16105 5 gallon
Ready to Use
Recommended replacement for Silicone Free Tire Dressing.
Hyper-Dressing - Until now, the industry average for diluting water based dressings has been one to one or ready-to-use. Meguiar's Hyper-Dressing dilutes up to four to one, varying the gloss from high to satin. One product, multiple uses...a winning combination for every professional and an industry first.
D-17001 1 gallon
D-17005 5 gallon
1:1 High Gloss
2:1 Medium Gloss
3:1 Satin Finish
4:1 Natural Shine
Recommended replacement for W-Dressing and Engine Kote.
Accent Dressing - Meguiar's Accent Dressing instantly beatifies and protects vinyl, rubber and plastic surfaces. This easy to use aerosol is ideal for exterior trim and hard to reach interior surfaces.
D-4610 10 ounce
Leather Cleaner & Conditioner - Meguiar's Leather Cleaner & Conditioner is expressly formulated to enhance the appearance of interior leather and vinyl surface. Specialized cleaning and conditioning agents are designed to safely clean and restore leather's original look and suppleness.
D-18001 1 gallon
Ready to Use
Lastly, also new from the Professional Line
Detailing Clay
Quickly removes all bonded contaminates
Restores smooth as glass finish
100% non-abrasive - safe on all types of paint
Two grades available to suit your needs,
Mild (C-2000) 200g
Aggressive (C-2100) 200g
rjstaaf and Mike,
THANK YOU!
Mike,
I know you've been a big fan of APC+ and CitriGel. Have you tried the new products?
If so, how do they stack up?
If not, please let us know when you do, K?
TomAs the light changed from red to green to yellow and back to red again, I sat there thinking about life. Was it nothing more than a bunch of honking and yelling? Sometimes it seemed that way.
Last Touch -
Ready to Use
Thanks.
Originally posted by Inzane
Just curious, when using Final Detail as a clay lubricant do you recommend the same 1:1 dilution with water? (or is Last Touch more concentrated than FD, requiring the dilution?) I've clayed with FD full-strength, but given that the jug I have of FD is probably the last I'll ever see since its discontinued I wouldn't mind making my limited supply last as long as possible.
Thanks.
It isn't suggested to dilute Final Detail, though. You could always try it with a small amount to see how it works out for you.
