Super Soap:
Engineered for high production detail environments, this rich foaming wash has special lubricating properties to help minimize scratching delicate clear coats. The foam is stable while washing, however specifically designed to break down quickly when rinsing for extra speed and efficiency.
Water Based Dressing:
This water based all purpose dressing restores shine and luster to vinyl, plastic, leather and rubber surfaces. May be used on both exterior and interior surfaces including engines. Spray and wipe at full strength for high gloss application or dilute 1:1 for a natural low gloss look.
All Purpose Cleaner+ :
This all surface cleaner is ideally suited for today's fast paced, high volume, detail operations where one simple solution is needed for a variety of cleaning needs. It provides mixtures for heavy cleaning of engines and tires, fast interior cleaning, as well as low foam ratio for use in carpet and upholstery extraction machines. leaves carpet clean, smelling pleasant, and the fibers soft with no sticky residue. Safe for clear plastic, glass and leather.
