Polishing oils in the Marine line cleaning products.
  • Polishing oils in the Marine line cleaning products.
    I have an older, well cared for fiberglass boat that has slight oxidation. I am looking for a product from the marine line that removes oxidation and is rich in polishing oils. Kind of like a M80 for boats. I use the M45 after cleaning I was just wishing I could also add more oils in my cleaning process. Is there anything available in the marine line? Between the M44, M49, and the M67, which has the most polishing oils? Thanks.
    Re: Polishing oils in the Marine line cleaning products.
    I'm thinking that M-45 is going to have the most oils.
    I may be completely wrong, but I think of M-45 as M-7 for fiber-glass/gel-coat.
    Bill
      What are you trying to do?
      Your saying you want more oil in the products but that's not clear.
      Are you looking for more working time?
      More polishing action?
      Or just the oiliest product out there?
      DetailingByM.com
        I am just trying to find out which Meguiars products designed for oxidation removal have polishing oils added. With gelcoat being so porous I would like to use every opportunity to nourish it with oils.
          I'd go with 45
          Here's the product discription:
          Restores brilliant gloss on fiberglass and painted marine or RV surfaces after cleaning. Restores valuable oils to feed and nourish the fiberglass or painted surfaces. Especially effective on dark colors. *Use polish only after the surface has been cleaned and restored to a “like new” or “average” finish.
          DetailingByM.com
