Flagship Ultimate Quik Wax
  • Flagship Ultimate Quik Wax
    Product attributes:
    • Mist on, wipe off...
    • Can be applied in direct sunlight
    • Marine’s longest lasting protection from a spray wax
    • No white residue!
    • Contains Hydrophobic Polymer Technology
    Part Number: M14016
    Size:
    16 ounce
    MSRP:
    $16.49
    Re: Flagship Ultimate Quik Wax
    Some heavy Quick Wax going on......
      How does this differ from UQW/Xpress Synthetic spray wax?
      Different market?
        This has a little bit of a surface cleaning ability, but it's very similar to UQW
          Would this product harm a cars finish? I'm assuming that it is stronger than the regular UQW...longer lasting? Tougher?
            No, it won't harm automotive paint. While very similar to UQW it isn't literally the same product in a different bottle, but you'd be hard pressed to see any major differences when using it on your car compared to UQW. On a gel coat it will do a little better job removing fresh water spotting, but that's generally less of a common issue than on your car. Note: this does not mean that this product will remove baked in water spots from the reclaimed water often used in sprinkler systems.
            But compared to UQW with regard to longer lasting or better protecting, you're splitting hairs. Better to stick with UQW for your car due to wider availability, or go with D156 Synthetic X-Press Spray Wax if you find yourself using a lot of the UQW.
              Thanks Michael...just wondered...was thinking along the lines of the harsh environment boats are subjected too...and just figured it would be extremely tough...maybe a good thing to use on your car in the winter driving.
