RV oxidation removal advice
  • RV oxidation removal advice
    Need to learn from the experts. I own a pressure washing company which encompasses 90% of my crews work. But from October through April I have found that the snowbirds and local RV owners can be a very lucrative market, keeping a day crew busy full time.
    Been detailing and restoring my own vintage and muscle cars for years, and am a perfectionist at heart. The AZ sun really takes a toll on the gelcoat finishes on the RV's and fifth wheels /travel trailers. Started offering oxidation removal last year. Been doing it by hand (well not by "hand", using cotton rags and nylon scrubbers). EXTREMELY labor intensive. And I have yet to get one with a uniform finish. So far my customers have been extremely pleased, but I know there must be a more officiant and professional method.
    Been reading a lot on this forum, as I am a member and moderator of several other forums and not your average "newbie" who needs to be told to use the search and do some research. Looks like I need to invest in a couple DA's. Which do you pro's recommend ? I have read some like the Porter Cable and then Meguirars has there own brand.
    Maybe even more importantly, I'd appreciate learning from you all the steps you have found to work the best. Which products, pads, setting speeds, ect.
    Sure wish I had more than appreciation to share in return. Anyone thinking about expanding into the pressure washing field, I'd be more than willing to help you get started.
    Thanks in advance.
    James Cooney
    Owner
    http://GrimeBustersPressureWashing.com
    Re: RV oxidation removal advice
    James, just a few hours ago we introduced our new, updated G110v2 dual action polisher featuring some significant upgrades and boasting some features not found in similar tools. This will be an excellent tool for your business.
    Our two primary products for oxidation removal on gel coats would be our M44 Color Restorer and M49 Heavy Duty Oxidation Remover, with the M49 being the more aggressive of the two. Both can be used with a W8207 foam polishing pad on the G110v2 and many have had great success stepping up to a W7207 foam cutting pad for more stubborn oxidation, scratches, etc. We normally don't recommend using a cutting pad on a dual action polisher because it tends to scour paint, but gel coat is quite different. With either pad you would generally run at speed 5 and work an area roughly 2' square for a few minutes until the product has become very thin on the surface, then wipe off the residue and move on to the next section.
    A great follow up is our M45 Polish for adding extra gloss and depth of color. This is a pure polish that really gets soaked into the pores of a gel coat and it can do wonders prior to your wax when you're looking for the best shine you can get. Speaking of wax, our top product for waxing gel coat finishes would be our Flagship Premium Marine Wax - very easy to use, dries quickly and offers the most protection and longevity in our lineup.
      Thanks Michael, much appreciated.
      The G110v2 is available now, or is it soon to be released ?
      Also, where can I buy volume discount M44 & M49, along with the yellow and burgundy pads ?
      Thanks once again for your willingness to help.
      James Cooney
      Owner
        The G110v2 was just announced today and should be available through various online retailers as early as the end of this month.
        Define "volume discount" for M44 & M49. In order to purchase direct from Meguiar's (ie, set up an account) you need to purchase several thousands dollars worth of product each month. You might try talking to a larger distributor, anywhere from places like Autogeek.net, Autodetailingsolutions.com or Detailing.com to local distributors such as CarQuest or even NAPA. The latter two will often allow you to set up an account and can work out special pricing. They should have our Marine/RV line available to them as well.
          Thanks once again Michael.
          James Cooney
          Owner
            I have lived fulltime in my motorhome for 13 years now and manage an RV store in the winter months in So. Ca. I can tell you from personal experience that going from doing it by hand to using the G110 and the maroon cutting pad....produced absolute night and day different results!! and saved my arms. There are about 6 teams of RV detailers working in our resort in the winter months and most of them use pressure washers and then various machines to polish the RVs. The products they use are varied and some are "secret". Getting an "even" coverage on fiberglass by hand is impossible in my opinion and experience. If oxidation is an issue, it often takes a second application of the same or different product to get full coverage and no splotchy looking results.
            Barry
              Thank you Barry for your input, much appreciated.
              James Cooney
              Owner
                So I received my 110V2 this week, along with a supply of #45, #49, #50 & #56. Did my first RV restoration over the past 2 days, and all I can say is WOW !!!!
                The products work like magic, did the medium grade oxidation job in 16 hours. Only problem I encountered was the backing plate broke off at the base yesterday. Had to drive at mach 2 to Chandler to ADS so I could pick up a couple more (now I have a spare one).
                White gel coats don't photograph well, but here are the before and after photo's :
                Thanks once again to all that have offered their expertise and willingness to help. Have another RV scheduled for Tuesday.
                James Cooney
                Owner
                  Hey James, nice job on the RV! I know how hard it is to get a gel coat restoration to show up in pictures.
                  I live in Az too and I've done a couple RV's lately and know what you mean about the Az sun killing a gelcoat.
                  I checked out your website, your powerwashing jobs turned out really nice...I sent you a PM by the way...good job!
                  Wills Amstutz
                  Windows And Wheels Auto Detailing LLC
                  www.WindowsAndWheels.com
                  'Like' Us On Facebook
                    So I received my 110V2 this week, along with a supply of #45, #49, #50 & #56. Did my first RV restoration over the past 2 days, and all I can say is WOW !!!!...
                    Checked your photobucket, it looks so much better now. I should say that was a very fine work, an inspiration. Sounds exciting that you have another one on Tuesday. Please keep updating.
                      Did you notice he made that post back in March?
                      Wills Amstutz
                        WOW! Backing plate burned off after two days worth of work??? Is it just me or does that not sound right?
                          Hi James, I saw your thread and your pictures. Your restoration job on the RV looks great! My RV is the same colour (off white) and I am currently working on bringing back the lustre. Its a 2000 and not sure when or if it has had any maintenance on the gelcoat (Ive only had it a year). I cleaned and conditioned the vinyl roof yesterday, and began removing the oxidation on the gelcoat. I can see its going to be a lot of work, and have decided to pick up a dual action polisher today (I was only able to get through 1/2 of one side yesterday!). I have a few questions of you: 1 - Which products did you use, and for what (I used M40 and M50 to deoxidize and try and bring back gloss); 2 - How did you treat/clean/care for the decals? Did you go right over them, or around them? My decals bleed if I go over them, and bleed when I clean them. I used the vinyl and rubber care on them, but not sure if its the right product? 3 - any other advice, suggestions would be appreciated! Thanks, Susan
                            hi mr stoops. can the yellow 8006 pad be used with m44 and 49, m50? also, can the m26 be used in place of your flagship pure wax?
