Question on Bad Oxidation, photos included
  • Question on Bad Oxidation, photos included
    I currently am working on a 1992 Crownline that has not been washed in at least 5 years they sad. Heavy oxidation and many scratches from the dock (found about 2 cases of beer cans so not surprised). I washed it using Megs Gold Class and then hit it with 105 on a Megs W400 wool pad on my Dewalt Rotary with fast results and it looked good. I then hit it with 205 using the rotary with Megs W800. I topped it off with Megs Boat Wax. It looked fantastic and then this morning I went to finish it and noticed the oxidation was back already. I thought maybe it was the shade or something when I originally buffed it so I went at it again with 205, no improvement and then with 105 followed by 205, no improvement again.
    The customer is going to be ecstatic with it but I am not. Does anybody have any other ideas on this or do I just chalk it up as it is as good as it is going to get?
    Photos
    This morning:
    After 105 and 205 for again:
    Any help would be appreciated!! Thanks!
    Re: Question on Bad Oxidation, photos included
    Well, I'd wash the wheels on that trailer, for one thing!
      Its possible that if the paint is shot, its shot.
        You might try buffing with some M45 Boat Polish or some #3 Machine Glaze. #3 Machine Glaze should be fairly easy to find at any PBE Store.
        Clean a section with the M205 about 2' by 2', this will effectively remove any wax and get you back to a clean base.
        Now try machine polishing this section with a pure polish like the M45 or M03, you could opt for M07 but it's not recommended for application with a rotary buffer, DA, Hand or Orbital.
        After really doing a good job of polishing this section now apply a coat of your boat wax and then see what happens.
        That looks like a blue gel-coat boat and if so then the polishing oils should penetrate into the gel-coat to some level and help to bring out the color and create a more uniform appearance. Then seal it up with wax.
        If this doesn't help then you have two options, re-cut with the M105 and really chew off some material to get past the dead gel-coat or call it good and accept that it might not be able to be fixed.
          Pic 5 is what I have going on with mine (only in white). Getting shiny, but still has oxidation.
          Mike, i see you recommending auto products, I thought you suggested using Boat/RV products for fiberglass due to the nature of much harder gelcoat vs. auto paint.
          For my problem, I ordered the M91 Heavy Cut Compound and a Solo pad. Will see how it turns out.
            The automotive products are "pure poshes" with high concentrations of Meguiar's polishing oils, gel-coats are usually porous enough to absorb these oils and this will do two things,
            1) It will fill any voids in the gel-coat with these oils so water can't take up residency and cause oxidation
            2) It will bring out the color of the gel-coat. (Even white gel-coat).
            Compounding or chewing off the dead oxidized gel-coat is a great start but after that you want to re-introduce these polishing oils before applying wax. Otherwise you just expose a fresh layer of polyester resin and the seal over it with wax and it's the polishing process that revitalizes the color.
