I got a new-to-me boat this past weekend and i have decided that I am going to remove the old decals on the side of the boat and replace them with the newer style Supra decals. And before I put on the new decals I would like to give the boat a really nice shine to it, plus it is spring time and I would like to do it before it gets really hot outside.
So today I took the heat gun and some elbow grease and tried getting all of the stickers off the side of the boat. Not sure if you will be able to tell from the pics but its almost like there is a wax buildup along all of the edges of the stickers and there is a little color difference too. So I thought well, im going to try wetsanding it with 1500 grit sandpaper and getting out the pc and try to polish it...well from what I could tell I need to go up to like a 2000 grit sandpaper or get a little heavier cutting pad to remove the marring from the sandpaper.
I only have a pc right now, no rotary so this is all I have to work with.
What process would you use to shine this boat up? It does have some oxidation and I know that it can look alot better.
After sticker removal, if you look close to the bottom of the teat you can see the 'ghost stripes"
Before sticker removal
wax buildup
wax buildup
