the ultimate paint protection challenges - paint study by kc
  • the ultimate paint protection challenges - paint study by kc
    How do you gauge a person is car crazy or not?
    Answer
    1. Spend his time looking at his ride more than anyone else
    2. Clean her more than any other chores at home
    3. Willingly spend his fortune on lavished her, time & effort worth everything
    4. Called his ride by name
    I share something of my passion to many & of which this one particularly captivated my heart & soul of detailing
    remember this familiar ride.... 21 years of oxidized paint that was doomed for repainting even professional body shop says is beyond detailing correction
    my 1st attempts (12 months ago)
    pic after after 1st correctional detail
    this is why i called her 2face
    some may prefer this look
    Nissan 2face, that what I called her….i may not have the luxury looking ride or paint but it has been always my passion to detail & to maintained what I have restores.
    My paint on one side of the car is 21 years old of age & another restores last year & regularly maintained by bi monthly waxes & 6 months polish, as it is a non clear coated car (AKA single stage paint). Constantly facing the aging issue
    A good classic examples…would be…our house gates & grills….as it need to be painted yearly, otherwise the paint become dulls & oxidized
    The solution…a double stage paint was created to protect this aging process….clear coat paint……I may not have the luxury again to repaint my car…..but fortunate to have a special coating flown in special from US manufacture….AKA Alien coating
    This is my thesis done….studying on my car
    Paint defect correction…etched marked caused by prolong neglected birds dropping
    spot wet sanded for testing
    paint etched by this acidic droppings threat & wet sanded to level up & compound off
    Ta da
    wet sanded the rest of the 50% of my entire car
    Wet sanded the affected area to bring out the defect, 1500 grits sand paper used, followed by 2000 grits sand paper
    "Wet sanding" refers to sanding with specially designed sandpaper wrapped around a skinny sponge with water running on the sanding area to clean away paint/primer from the area you are sanding.
    "Block sanding" means putting a hard flat structure behind sand paper... use paint paddlesticks or small blocks of wood.
    sanding mark removed by compound & I choose M 105 for it aggressiveness & nos 12 cut in precision cutting scale
    a prefect 50/50 % comparison picture…to show the 21 years old paint which was oxidized & another side that was corrected
    pics before wet sanded
    after wet sanded down by 1500 grit sand paper & followed by 2000 grit sand paper
    perfectly & evenly sanded down……
    The sanding mark was removed by Megs # 105 with S/side wool pad , followed by Lake country Cutting pad with M# 105 & Polish by Megs 80 with Lake country Polishing pad
    Another 50/50 comparison pic after sanding mark removed
    there is some visible deep scratches is too deep to be removed…..as this car was terribly
    neglected for 21 years & paint was just left there to be oxidized. There are countless area where deep scratches inflicted by scotch bright dishes scrub, some are more severe as it seems, it has been brushes over metal bristle brushes
    4 months later
    Intervention plan…to maintained this Single coated paint, with minimal effort
    ONR No rinse Wash prior Claying (aggressive clay) & lube with ONR
    To removed paint imperfection before coating my single stage paint
    M#105 with Wool by rotary
    Followed by M# 105 with Lake country CCS
    Optimum Polish with LC polishing pad
    After pics
    tada
    prefect stage
    Apparently, this coating was design to with stand all harshness of weather & environmental threat. Counted my blessing to be able to attained this & having this extra ordinary water beaded results
    Pay attention to the blue tape mark area
    tape prior coating, it is an area that I coat without any corrections
    Pics after coated applied
    look at the 21 years old & oxidized paint
    300 watt Halogen lamp is no feat even in penetrating thru ….dead paint…dull & matt
    admiring the gloss at the corrected coated side ( on the engine bonnet area only)
    tada pics
    the car was left to cure for 48 hours….while we went for an outting
    3 days later some sun light pics
    some beading pics after some sunny drops
    the next day …….midst
    the roof part, Optimum ONR effect, water beading
    a week later
    prefect water beading pics…that I personally have not seen in my entire life…..look at the semi circle shaped water that’s beads up because of the surface tensioned
    8 days later
    Another morning midst & after over night rain pics
    [img]http://lh6.ggpht.com/_RsduO4BD4FA/TA8htjoc0_I/AAAAAAAAI5s/JjxVMCvfj9k
    2 months later…another prefect moments again…rain drop on 2face
    the protected side has better water beading & the neglected side water splattered…horizontally
    another unbelieving water beading picture, that I never seen on any single stage paint
    look at the clarity of the paint , remains even after 60 days
    67 days later
    extremely close up pics
    look at the prefect 50/50pics
    alien eggs???
    extreme close up pics
    this is the actual mail i received from a\our local - international detailing supplier chief technician
    Hi kc,
    After i looked the picture yes this is very bad oxidation and powdery aslo on roof top have few area getting Corrosion. i assume that this is not original paint,this is a single stage paint and also not a Clear coat paint so we can not call this is Clear Coat Failure.
    the paint is 30-40 years back - Paint Technology ( Alkyd Enamel Paint ) not 2k Paint ( Two Components Paint )
    Alkyd Enamel Paint - local we call slow dry paint or call Cat Biasa.
    the durability of alkyd enamel paint won't lasting as 2k paint,this is it different paint Categories
    Comparison between different system chart with attached.
    The only honest answer as to how to fix this problem is to re-paint the entire car.
    what would have happen if i just believe LUCK (what others says about me) ...& it ran out....
    in my conclusion.....there is 2 type of detailer here :-
    the 1st type - one who is constantly giving out his personal ideal of detailing (IMHO, IMO. MO) such as beg to defer kinda opinion
    the other ...who's ...........SHOW ME YOUR WORK detailer...the only thing they do is explores & have a personal encounters & not just another read some where or pick along the way......who says what kinda experience
    My life is never the same since detailing came into me.......as life is just like a box of chocolate ...u never know what it will comes out to be
    always expect the unexpected
    as all it takes is a little patience & plenty of passion
    stay tuned for more....his friend called joker
    Re: the ultimate paint protection challenges - paint study by kc
    So is the Alien Coating a paint?
      For some reason, KC calls ONR Alien juice so taking note of that "alien coating" is very likely to be just Optimum Opti-coat. You can tell he put the text in the image himself.
      Not surprising to me. Opti-coat puts a measurable coating on the paint and is not a regular sealant. It boasts upwards of 2 years protection.
      Alan T.
        Like his use of the term "alien eggs". Maybe it is his clever way of saying a "non meguiar's product?
          thanks
          LOL, i was actually called alien, as the way i detail...non stop & finishes a few in a roll...so my country men calls me alien...i like it
          very out of this world indeed...thanks guys for viewing
          cheers to #105/205...otherwise i would not have restored the paint
