Toyota Starlet '86 with single stage red paint
  • Toyota Starlet '86 with single stage red paint
    Hi,
    This was our toughest task ever. The 1986 Toyota car with the single stage paint had tons of oxidation around the body to say the least. Well, the pictures (before and after) I hope can tell the real challenge we faced. GlamSlam, our garage name, says hello to all of u. Thanks to all Mikes there in Meguiars HQ and also to TimG for your helps.
    Re: Toyota Starlet '86 with single stage red paint
    Did you post pictures?
    Did you post them correctly?
    Here is a thread on How To Post Pictures
      There's code behind the scenes for pictures, they're just not showing up?
      Example, the below is between the correct IMG tags?
        I didnt realize they are not showing up since everytime i open it the pictures are there for me. Is that because I did not have them in the galery? If im not mistaken ive read that we need to have pictures in the galery first and then we can somehow link them into the threads?
        Thanks guys for letting me know.
          Here is a Link:
          If you have the photos on a different website or even on Meguiars Online, try going to the large photo and right click it. If in that little menu it gives you an option of copy image location then do that. Then in your reply or post you will see an icon with mountians, pressing that. Next press ctrl and v. then click okay. the photo should then appear in the post.
            Thanks guys. Been fighting with the very slow typical indonesian internet connection. I hope this one works. Please let me know if I fail again. thanks!
            Here You Go!
              Wow, GREAT turn around!
                Thanks I finally posted them correctly. U did see the pics, right?. Thanks for all helps. And thanks for your compliment Mark.
                  Sure did- they look fantastic. I'm glad you got it figured out
                    Wow, your car looks great. What a save. Great job, way to go.
                      what a brilliant, improvement. whats products/tools did you use?
                        Wow! Great reflections!
                        If you could share the products and tools used, that'll be great mate.
                          Great save!
                          What do you think of working on single stage paints as compared to working on clear coat paints?
                          p.s.
                          Tweaked your code a little to make the full size images show up, basically removed this _m from the very end of the file name for the image which forces a Thumbnail photo to appear instead of the full size photo.
                            Holy Smokes!!!
                            Great Job!!
                            Glad you finally got the whole picture thing.
                            Looks Great!!
                            Sweet Reflections!!
                            Huge Improvement!!
                              Thanks man! I used 3m and meguiars products, and few IPOs for my cutting foam pad. We also used the meguiars' burgundy cutting pad since i think it is a bit softer than IPO's.
                              Started from the extra cut, compound power cleaner, cut and polish and finished with swirl remover and wax. We also mixed and matched the combo to gradually eliminate the barriers such us the very deep oxidation. Afraid of having the coat too thin, we cut too much on the top of the backdoor (not shown), creating a small cut on the paint (too bad). Overall, we applied more than 10 times and we used a lot of juice to lessen the friction.
                              For us, the task was overwhelming to say the least but we are glad its over, and are ready for the new ones.
                              Great save!
                              p.s.
                              Thanks carfire for being the first timer to let me know of the problem with the pictures. (for a second, i thought the work was so ugly none of you dared commenting).
                              And as always, thanks to you Mike. You are always there to help. Big time appreciation from me and GlamSlam.
                              We think that both offer different challenges. To me, it is easier to work on a clear coated base if the coat is still safe to play with. But if it is too thin, i'd rather work on the single stage paint. Hey u know the pads are all turning to different color after single stage work, aint that fun we have new colored pads?
                              I dont know why, the more I look at the pictures, i sure see the clear coated paint. Or maybe because we did the work...we appreciate it too much. LOL.
